3D printing service Kansas City, KS
FDM 3D Printing service in Kansas City, KS
SLS 3D Printing service in Kansas City, KS
MJF 3D Printing service in Kansas City, KS
SLA 3D Printing service in Kansas City, KS
Over 160 customers are satisfied with our 3D printing service.
“Great service. Have a friend in the industry who reviewed the parts that were sent and he could not believe how well done they were. Highly recommend this hub.”
Michael, Kansas City
Standard TPU, FDM
“Bryan very quickly had my order printed and stood behind every piece printed. I mentioned a slight fitment issue that was resolved with some minor sanding and he tweaked some settings and had a new one printing before I could stop him! Great service backed by a stand-up guy.”
Ryan, Kansas City
“Had a redo on the print. Still was delivered quickly. Absolutely wonder job on this and all prints.”
James, Lee's Summit
“Order filled faster than expected. Easy to work with.”
Scott, Carthage
Carbon-fiber reinforced Nylon, FDM
“Great looking parts. My go to for critical parts”
Touzong, Joplin
Standard resin, Material Jetting
“Best looking parts by far. Great dimensional accuracy!”
Touzong, Joplin
“Very happy with the service. Fast turn around and the print results are excellent! I used standard resin with 100 micron layering. There is no noticeable layering. I am using this part to replace another part that was originally cast with resin using an injection molding process. I designed the replacement part in Rhino with a LOT of detail that was not in the original. This 3D part is a LOT more detailed than the one I am replacing, and it is as smooth as the original.”
Doug
Standard resin, SLA/DLP
“Parts looked great - arrived right on time.”
Chris
“Very good quality and very fast printing, Thanks!”
Binghui
“Robert was amazingly fast, parts are great.”
Jim
“very intricate work. appreciate the work. awesome. thank you”
Jaeson
“Thanks for being flexible with the pickup time.”
Nate
“Good service and value. Planning to come back.”
Leming
“Very fast printing for a delicate model. Very good communication to make my initial design printable. Thank you. ”
Dan
“The prints turned out excellent! Thank you!”
Yun-Han
Standard Nylon, SLS
“Prints came out very nice, as expected, and they served their purpose.”
Enrique
“Fantastic service and print came out better than expected.”
Katie
“Fast and friendly. Maintained good communication.”
Jack
“There wasn't much interaction, so I can't give any feedback”
Humam
Standard Nylon, SLS
“Excellent service provider! I especially liked the time lapse, prompt updates, and quick delivery”
David
“FANTASTIC experience as always. Always nice to be a return customer. Will be back again!”
Matt
“You guys worked on the weekend, listened to my needs, gave great advice and got my print before my event!! Couldn't have been any better. Excellent.”
Robert
“Fast and high quality service, as always.”
Joseph
“Great communication, good quality print at a solid price point with excellent turnaround time.”
John
Standard Nylon, SLS
“Good parts and speed 2 time ordering and will keep ordering.”
Martin
