3D printing service San Francisco, CA
FDM 3D Printing service in San Francisco, CA
SLS 3D Printing service in San Francisco, CA
MJF 3D Printing service in San Francisco, CA
SLA 3D Printing service in San Francisco, CA
Over 141 customers are satisfied with our 3D printing service.
“Made exactly as ordered, came on time, and works great. ”
Christine, San Francisco
“Outstanding work. Fast, clean, easy to communicate with. Highly recommend and will send him more work. ”
Russ, San Francisco
“Thank you again! Awesome prints as usual.”
Keith, San Francisco
Transparent resin, Material Jetting
“Great service! Fast response and communication also accommodating to my requirements!”
Naufal, San Francisco
“Very fast, friendly and professional service.”
Anttoni, San Francisco
Standard resin, SLA/DLP
“Fantastic. Worked with me to deliver the best possible quality parts, and was willing to put in the extra time and effort to make everything just right.”
Scott, San Francisco
Standard TPU, FDM
“Outstanding print quality. My part was printed within one hour after she received the file. ”
Tian, san Francisco
Standard TPU, FDM
“Great prints, good price, with excellent turn around time, minimal part cleanup needed for finished parts”
Felipe, San Francisco
“Wonderful!!! the fastest printer i have meet, and the quality is also excellent!”
tian, SF
“Insanely fast, great quality, great communication.”
John, San Francisco
Standard Nylon, FDM
“Excellent communication, great print, hit deadlines.”
Abate, san francisco
Standard Nylon, SLS
“Overall great experience. Very good value for expectations.”
Mark, San Francisco
“Matt worked with me to ensure that the quality of the prints was what I expected and they met my needs! Thanks so much! ”
Rohan, Daly City
Standard PETG, FDM
“quick turnaround and great communication!”
Michael, Sausalito
Standard TPU, FDM
“Very responsive. Started print immediately and shipped quickly.”
Jules, Oakland
“ekim was great, fast, and the quality turned out great. ”
Christopher, Alameda
“The print was great, very good communication and speed. Recommended !”
Victor, Oakland
“The is my first getting 3d printed materials. It is slightly different than what I expected but in time I'll know what to expect. Great communication, speed.”
Steven, Hillsborough
“Excellent communication and service. Would definitely use their service again. The 3d part was pretty much perfect, and I am satisfied with the product that was sent to me. Thanks!”
Justin, NORTH RICHMOND
“Another great print! Great results with TPE for rubber prototype parts. ”
Eric, San Mateo
Standard TPU, FDM
“Super helpful communication, parts look great and arrived on time”
Perry, FOSTER CITY
“excellent service. part came out clean and exactly what i designed.”
Truman, FOSTER CITY
“Really great parts, went above and beyond to provide great service. Will definitely be using them again.”
Jonathan, San Leandro
“Great print, very communicative and helpful throughout the whole process. ”
Christopher, Belmont
“You did amazing work thank you so much my project is a success”
Tomer, Oakland
