CTC LTD
CTC-3D
7.1 / 10
The CTC-3D is a Chinese low-budget 3D printer, which bears close resemblance to the 1st gen. Makerbot Replicator. It can print in both PLA and ABS at a resolution of 100 microns. Stand-alone printing is possible and its build volume is 25 x 20 x 20 cm.
Budget
$587.00
Owner ratings (37)
7.1 / 10
8.2
7.0
7.1
7.1
8.3
4.8
7.5
6.0
6.7
8.2
Material availability
Dual extruder
Design
Customer support
ABS, PLA
22.5 x 14.5 x 15 cm
500 microns
2
XY precision
11 microns
35-40 mm/s
Target audience
beginner
intermediate
CTC can be used out of the box but I wouldn't advise it to anyone that doesn't have the confidence to tinker with the printer. But if you do like tinkering this print has some good upgrades to make it print really nice.
To be hones for low cost this is the best. I didn't investigate other printers, but it's housing is great so you can close it all over it with some glass to print ABS. Dual head is great so you can use first, second or both head with different colours. It would be great to print faster with good quality, maybe it does and I didn't set it right :)
Super printer for a very cheap price if you look around! (as little as ‎€350)
This printer still impresses me even after a year of bad treatments and long hour prints. Levelling can be tricky but other than that, amazing stuff! Very little maintenance and haven't had any major issues with it, and the price has been going down even!
6.4 / 10
It's a direct clone of the MakerBot Replicator 1 Dual, at a fraction of the price. It was already an amazing value when I bought it, and now the price has dropped by half! The biggest downside is that to really reach its full potential, you need to shell out for Simplify3D to do your slicing and run the printer. (I feel this goes for any FDM/FFF printer though.)
Great printer for the money!
Great machine based on one of the best printers, but it needs a lot of upgrades to function properly.
an overall great experience Perfect for low budget projects and non finals ones
6.2 / 10
It's a good first printer.
6.0 / 10
Goo printer for small price some upgrafes to do
6.0 / 10
Great printer for the value
My CTC was literally plug and play when I received it. Out of the box it was nearly dead on, and only took one belt adjustment to print perfectly in calibration. Print quality if quite good for the money. I don't think there is another printer out there that offers better band for the buck.
4.8 / 10
Good printer for small price but needs some upgrades
A fairly low cost 3d printer offering dual extrusion and a larger than average build area for a great price. The, printer is very fast, precise and in my experience the build quality is really up there with higher priced competition. If this machine came with an all metal extruder I would consider it one of the top machines of this size available. Having said that I upgraded mine in 20 minutes... Great little machine, accurate, fast, reliable and cheap to run.
I bought this for the price, if you are tech savvy then it can work wonders. Easily a great first printer with many capabilities versus the competition; heated bed, enclosure, dual extruders.
Works like advertised
At 1st glance it seems a great entry level printer with its low cost and comparatively large build volume. This is what got me hooked at 1st. However now I have several printer including some large industrial machine I still find myself using the ctc. Its fast, precise, its print quality truly rivals its much more expensive competitors and printing with ABS I genuinely only get about 1 failure in 50. The last bit could be down to experience for sure. But it still shows this printer really can run with the big boys in the 3d print world.
6.0 / 10
A great first printer with many capabilities for the price. You will need to be tech savvy in the long run with maintenance & upkeep, but otherwise a great value to learn how to print.
5.2 / 10
It's cheap, you can get reasonable print quality for the price
Its been a good steady workhorse for well over a year, it prints 10-12 hours a day without a flae
