Ord Bot Hadron
The ORD Bot is a version of the Printrbot design built around Makerslide: structural aluminum extrusion with bearing surfaces molded into each side. This improves frame stiffness, mechanical reliability and print speed, the only downside to which is an increase in cost.
The ORDBot is a high quality kit reprap machine that gives excellent quality for a good price. The frame is very rigid and it can run very quickly while maintaining quality prints. I t is not plug and play, so its better suited to makers and hobby pros.
The ORD Bot Hardon is delivered as a self assembly kit (Prusa i3 alike). It was my first 3d printer. Assembly was quick and asy and it worked from the beginning without lot adjustments. Especially the Bulldog-XL Extruder with Hexagon Hotend is a perfect combination. I never had clogs and different filaments (PLA, ABS, PETG) can be changed without any hassle.
It is a work horse. Is working 24/7 with no problems.
It works 24/7 with no problems
Good printer, many mods you can print to it to make it better
