3D Systems
ProJet 660Pro
$59,650.00
3D System's high-end full color printer for professional use. Ideal for stop motion animation, professional model shops, architects, consumer product design and development, digital manufacturing, fine art production and more. It prints to a resolution of 600 x 540 dpi and has a build size of 25.4 x 38.1 x 20.3 cm.
Professional
Owner ratings (14)
8.4
6.7
8.9
7.0
6.6
5.1
1.3
7.3
5.9
Speed
Material availability
Running costs
Jetting
VisiJet PLX
28mm/h
Ethernet
Target audience
pro
6.2 / 10
The Projet660 has the ability to provide a very wide range of colors, which is nearly impossible for all other types of 3D printing. It is also advantageous to printing with powder if budget costs are tight.
It's the best solution in the market to get full color 3D prints with a moderate cost.
6.0 / 10
printing material is way too expensive
Prints colour as it should, little else in the way of options
It is an expensive printer but the quality is very good
The fastest, greenest and most colorful 3D printer on the market
Amasing how the products look
It is a fully functional professional tool and if u have it clean and maintained your only problem will be the quality of the files that u use. Also be prepared for the running cost of the materials and the post processing.
