Wanhao
Wanhao Duplicator 4S
7.5 / 10
The Wanhao Duplicator 4S is an FDM printer with a build volume of 22.5 x 14.5 x 15 cm. It has a dual extruder that can print two build materials such as ABS, PLA and other filaments or it can use dissolvable support material such as PLA to print . The Wanhao can reach 100-500 microns layer height.
Budget
$999.00
Owner ratings (17)
7.5 / 10
8.4
7.2
8.9
7.6
8.9
6.7
7.1
6.1
5.5
8.2
Material availability
Dual extruder
PLA
22.5 x 14.5 x 15 cm
500 microns
2
XY precision
11 microns
40 mm/s
Only software
It is my first printer. Great for teaching how to print.
5.6 / 10
Great printer but it takes some patience. Luckily the support is there in customer service.
Steel frame, stays put mostly, throws extruders every once in a while.
7.3 / 10
Very good if you use better software. Simplify3D for example.
6.0 / 10
A good first time experience, out of the box, leveled the bed and printed something right away...
Its great
5.3 / 10
It's a good machine for someone with some technical background. For the price, it's well built. The software it comes with isn't all that great. Adding good software increases the price.
