1. 3D printing
  2. Fiber reinforced
Fiber reinforced
Fiber reinforced materials are filled with continuous fibers or fiber particles that result in parts with improved physical properties and high stiffness.
FDM Fiber reinforced Materials
Benefits and Limitations
Fast turnaround times
Carbon-fiber reinforced Nylon
Carbon-fibre reinforced Nylon (FDM) contains continuous carbon fibers that give extremely high stiffness and strength-to-weight ratio comparable to metal.
Material family
Carbon filled Nylon
Carbon filled Nylon (FDM) has excellent stiffness and good temperature resistance. Ranks between standard Nylon and continuous Carbon-fiber reinforced Nylon.
Material family
Kevlar-fiber reinforced Nylon
Kevlar-fiber reinforced Nylon (FDM) contains continuous kevlar fibers that give excellent mechanical properties and high abrasion and impact resistance.
Material family
Fiberglass reinforced Nylon
Fiberglass reinforced Nylon (FDM) contains continuous glass fibers that give high stiffness and excellent heat resistance. Ideal for high temperature applications.
Material family
SLS Fiber reinforced Materials
SLS is used for both prototyping and small-batch production of functional plastic parts with good mechanical properties.
Longer lead times than FDM
Price $$$$$ Tolerance ± 0.3% (min: ± 0.3 mm)
Turnaround time < 5 days Wall thickness 0.7 mm
Max part size 75 x 55 x 55 cm Layer height 80 - 120 μm
Carbon filled Nylon
Carbon filled Nylon (SLS) contains carbon fiber or graphite particles that give parts high stiffness and improved thermal properties over standard Nylon.
Material family
Glass filled Nylon
Glass filled Nylon (SLS) contains glass particles that give parts high stiffness and improved thermal and abrasion resistance over standard Nylon.
Material family
