1. 3D printing
  2. Flame retardant
Flame retardant
Flame retardant, certified thermoplastics made with the SLS or FDM printing process.
SLS Flame retardant Materials
SLS is used for both prototyping and small-batch production of functional plastic parts with good mechanical properties.
Benefits and Limitations
Longer lead times than FDM
Price $$$$$ Tolerance ± 0.3% (min: ± 0.3 mm)
Turnaround time < 5 days Wall thickness 0.7 mm
Max part size 75 x 55 x 55 cm Layer height 80 - 120 μm
Flame retardant Nylon
Flame retardant Nylon (SLS) are certified PA materials for consumer applications and aviation with great mechanical properties.
Material family
FDM Flame retardant Materials
Fast turnaround times
Standard PEI (ULTEM)
ULTEM (FDM) is an engineering plastic with good mechanical properties and exceptional heat, chemical and flame resistance. Suitable for top-end applications.
Material family
