1. 3D printing
  2. Food safe
Food safe
Materials that are certified as food safe.
FDM Food safe Materials
Benefits and Limitations
Fast turnaround times
Standard PEI (ULTEM)
ULTEM (FDM) is an engineering plastic with good mechanical properties and exceptional heat, chemical and flame resistance. Suitable for top-end applications.
Material family
Standard PETG
PETG (FDM) is a thermoplastic material with improved mechanical properties over PLA and excellent chemical and moisture resistance.
Material family
