1. 3D printing
  2. Heat resistant
Heat resistant
High heat resistant 3D printing materials with a Heat Deflection Temperature (HDT) greater than 100°C (0.45 MPa).
DMLS/SLM Heat resistant Materials
DMLS/SLM produce high performance, end-use metal 3D printed parts for industrial applications in aerospace, automotive and medical.
Benefits and Limitations
High Cost
Price $$$$$ Tolerance ± 0.1 mm
Turnaround time < 10 days Wall thickness 0.4 mm
Max part size 50 x 28 x 36 cm Layer height 20 – 50 μm
Cobalt-chrome
Cobalt-chrome (DMLS/SLM) is a high corrosion and wear resistant materials with excellent temperature resistance. Suitable for biomedical applications.
Material family
Inconel
Inconel (DMLS/SLM) is a metal super-alloy with excellent tensile, fatigue, creep, and rupture strength, ideal for high-temperature applications.
Material family
Nickel alloy
Nickel Alloys (DMLS/SLM) are metal super-alloys with extreme heat and corrosion resistance.
Material family
SLA/DLP Heat resistant Materials
SLA is most suitable for visual applications where an injection mold-like, smooth surface finish, and a high level of feature detail are required.
Smooth, injection mold-like, surface finish
Brittle, not recommended for functional parts
Price $$$$$ Tolerance ± 0.5% (min: ± 0.1 mm)
Turnaround time < 2 days Wall thickness 0.5 mm
Max part size 150 x 75 x 50 cm Layer height 25 - 100 μm
Heat resistant resin
Heat resistant resin (SLA) has high strength and stiffness and excellent temperature resistance. Used for low-cost, low-run injection molds.
Material family
Ceramic filled Resin
Ceramic filled resin (SLA/DLP) produces parts with very high stiffness and higher detail than Tough or Durable resin. Good temperature resistance.
Material family
Material Jetting Heat resistant Materials
Material Jetting produces parts of the highest dimensional accuracy with very smooth surface finish, used for both visual prototypes and tooling manufacturing.
Smooth, injection molding-like finish
Brittle, not recomemended for functional parts
Price $$$$$ Tolerance ± 0.1% (min: ± 0.05 mm)
Turnaround time < 5 days Wall thickness 1.0 mm
Max part size 100 x 80 x 50 cm Layer height 16 - 32 μm
Heat resistant resin (Material Jetting) has high strength and heat deflection temperature and can be used to produce high detail, low-run injection molds.
Material family
FDM Heat resistant Materials
Fast turnaround times
Standard PEI (ULTEM)
ULTEM (FDM) is an engineering plastic with good mechanical properties and exceptional heat, chemical and flame resistance. Suitable for top-end applications.
Material family
Fiberglass reinforced Nylon
Fiberglass reinforced Nylon (FDM) contains continuous glass fibers that give high stiffness and excellent heat resistance. Ideal for high temperature applications.
Material family
