1. 3D printing
  2. High detail
High detail
Parts with high feature detail using SLA/DLP or Material Jetting processes.
SLA/DLP High detail Materials
SLA is most suitable for visual applications where an injection mold-like, smooth surface finish, and a high level of feature detail are required.
Benefits and Limitations
Smooth, injection mold-like, surface finish
Brittle, not recommended for functional parts
Price $$$$$ Tolerance ± 0.5% (min: ± 0.1 mm)
Turnaround time < 2 days Wall thickness 0.5 mm
Max part size 150 x 75 x 50 cm Layer height 25 - 100 μm
Standard resin
Standard resin (SLA) is a high-detail resin that produces parts with a smooth, injection mold-like surface finish. It is brittle and used for non-functional parts.
Material family
Clear resin
Clear resin (SLA) has a semi-transparent appearance, but can be post processed to a smooth and almost fully optically clear finish.
Material family
Heat resistant resin
Heat resistant resin (SLA) has high strength and stiffness and excellent temperature resistance. Used for low-cost, low-run injection molds.
Material family
Ceramic filled Resin
Ceramic filled resin (SLA/DLP) produces parts with very high stiffness and higher detail than Tough or Durable resin. Good temperature resistance.
Material family
Castable resin
Castable resin (SLA) is a high-detail resin used to produces patterns for investment casting. They burn out cleanly with no ash or residue.
Material family
Dental resin
Dental resins (SLA) are high-detail, sterilizable and biocompatible resins capable of producing dental implants.
Material family
Material Jetting High detail Materials
Material Jetting produces parts of the highest dimensional accuracy with very smooth surface finish, used for both visual prototypes and tooling manufacturing.
Smooth, injection molding-like finish
Brittle, not recomemended for functional parts
Price $$$$$ Tolerance ± 0.1% (min: ± 0.05 mm)
Turnaround time < 5 days Wall thickness 1.0 mm
Max part size 100 x 80 x 50 cm Layer height 16 - 32 μm
Standard resin
Standard Resin (Material Jetting) produces extreme detail, rigid, injection mold-like parts with a smooth surface. Used for top-end visual, non-functional prototyping.
Material family
Digital ABS
Digital ABS (Material Jetting) mimics the properties of ABS and produces stiff, rigid parts for engineering applications. Greater detail than Tough Resin (SLA).
Material family
Durable resin (PP-like)
Durable resin (Material Jetting) mimics the properties of PP and is semi-flexible. Ideal for durable, high-detail prototypes. Greater detail than Durable Resin (SLA).
Material family
Transparent resin
Transparent resin (Material Jetting) has a completely 100% clear, glass-like appearance and is ideal for prototypes that resemble real injection molded parts.
Material family
Rubber-like resin
Rubber-like resin (Material Jetting) produces high-detail parts with a soft rubber-like appearance and shore hardness < 70A. Not suitable for functional prototypes.
Material family
Heat resistant resin (Material Jetting) has high strength and heat deflection temperature and can be used to produce high detail, low-run injection molds.
Material family
Castable resin
Castable resins (Material Jetting) are high detail resins for investment casting pattern making. No residue after burn out. Greater detail than Castable Resin (SLA).
Material family
Dental resin
Dental resins (Material Jetting) are high detail, sterilizable and biocompatible resins suitable for dental implants. Greater detail than Castable Resin (SLA).
Material family
