1. 3D printing
  2. High stiffness
High stiffness
High stiffness plastics and metals with a Modulus of Elasticity greater than 2 GPa, available in all 3D printing processes.
Material Jetting High stiffness Materials
Material Jetting produces parts of the highest dimensional accuracy with very smooth surface finish, used for both visual prototypes and tooling manufacturing.
Benefits and Limitations
Smooth, injection molding-like finish
Brittle, not recomemended for functional parts
Price $$$$$ Tolerance ± 0.1% (min: ± 0.05 mm)
Turnaround time < 5 days Wall thickness 1.0 mm
Max part size 100 x 80 x 50 cm Layer height 16 - 32 μm
Digital ABS
Digital ABS (Material Jetting) mimics the properties of ABS and produces stiff, rigid parts for engineering applications. Greater detail than Tough Resin (SLA).
Material family
SLA/DLP High stiffness Materials
SLA is most suitable for visual applications where an injection mold-like, smooth surface finish, and a high level of feature detail are required.
Smooth, injection mold-like, surface finish
Brittle, not recommended for functional parts
Price $$$$$ Tolerance ± 0.5% (min: ± 0.1 mm)
Turnaround time < 2 days Wall thickness 0.5 mm
Max part size 150 x 75 x 50 cm Layer height 25 - 100 μm
Tough resin (ABS-like)
Tough resin (SLA) mimics the properties of ABS and produces parts with improved mechanical properties compared to standard resin. Can be used for functional parts.
Material family
Ceramic filled Resin
Ceramic filled resin (SLA/DLP) produces parts with very high stiffness and higher detail than Tough or Durable resin. Good temperature resistance.
Material family
FDM High stiffness Materials
Fast turnaround times
Carbon-fiber reinforced Nylon
Carbon-fibre reinforced Nylon (FDM) contains continuous carbon fibers that give extremely high stiffness and strength-to-weight ratio comparable to metal.
Material family
Carbon filled Nylon
Carbon filled Nylon (FDM) has excellent stiffness and good temperature resistance. Ranks between standard Nylon and continuous Carbon-fiber reinforced Nylon.
Material family
Fiberglass reinforced Nylon
Fiberglass reinforced Nylon (FDM) contains continuous glass fibers that give high stiffness and excellent heat resistance. Ideal for high temperature applications.
Material family
