1. 3D printing
  2. High strength
High strength
High strength plastics and metals with tensile strength greater than 45 MPa.
DMLS/SLM High strength Materials
DMLS/SLM produce high performance, end-use metal 3D printed parts for industrial applications in aerospace, automotive and medical.
Benefits and Limitations
High Cost
Price $$$$$ Tolerance ± 0.1 mm
Turnaround time < 10 days Wall thickness 0.4 mm
Max part size 50 x 28 x 36 cm Layer height 20 – 50 μm
Stainless steel 316
Stainless steel (DMLS/SLM) has high ductility and excellent corrosion resistance. It produces fully dense parts for industrial applications.
Material family
Cobalt-chrome
Cobalt-chrome (DMLS/SLM) is a high corrosion and wear resistant materials with excellent temperature resistance. Suitable for biomedical applications.
Material family
Inconel
Inconel (DMLS/SLM) is a metal super-alloy with excellent tensile, fatigue, creep, and rupture strength, ideal for high-temperature applications.
Material family
Aluminum (DMLS/SLM) is a low-density metal with great mechanical and thermal properties and good electrical conductivity.
Properties
Material family
Titanium
Titanium (DMLS/SLM) has excellent mechanical properties, corrosion resistance and strength-to-weight ratio. It is sterilizable and biocompatible.
Material family
Nickel alloy
Nickel Alloys (DMLS/SLM) are metal super-alloys with extreme heat and corrosion resistance.
Material family
SLS High strength Materials
SLS is used for both prototyping and small-batch production of functional plastic parts with good mechanical properties.
Longer lead times than FDM
Price $$$$$ Tolerance ± 0.3% (min: ± 0.3 mm)
Turnaround time < 5 days Wall thickness 0.7 mm
Max part size 75 x 55 x 55 cm Layer height 80 - 120 μm
Standard Nylon
Standard Nylon (SLS) - PA 12 - has all-around great mechanical properties and chemical resistance and is ideal for functional parts and prototypes.
Material family
Carbon filled Nylon
Carbon filled Nylon (SLS) contains carbon fiber or graphite particles that give parts high stiffness and improved thermal properties over standard Nylon.
Material family
Glass filled Nylon
Glass filled Nylon (SLS) contains glass particles that give parts high stiffness and improved thermal and abrasion resistance over standard Nylon.
Material family
Mineral filled Nylon
Mineral filled Nylon (SLS) contains mineral particles that give parts higher stiffness, thermal stability and density over standard Nylon.
Properties
Material family
Aluminum filled Nylon
Aluminum filled Nylon (SLS) contains aluminum particles that give parts a metallic appearance, improved stiffness over standard Nylon and great machinability.
Properties
Material family
Nylon 11
Nylon 11 (SLS) - PA 11 - has higher impact resistance and is more flexible than standard Nylon (PA 12), but has lower hardness.
Material family
Flame retardant Nylon
Flame retardant Nylon (SLS) are certified PA materials for consumer applications and aviation with great mechanical properties.
Material family
FDM High strength Materials
Fast turnaround times
Standard Nylon
Nylon (FDM) has superior mechanical properties than ABS and high chemical and abrasion resistance. Used for functional parts requiring high fatigue strength.
Properties
Material family
Standard PEI (ULTEM)
ULTEM (FDM) is an engineering plastic with good mechanical properties and exceptional heat, chemical and flame resistance. Suitable for top-end applications.
Material family
Carbon-fiber reinforced Nylon
Carbon-fibre reinforced Nylon (FDM) contains continuous carbon fibers that give extremely high stiffness and strength-to-weight ratio comparable to metal.
Material family
Carbon filled Nylon
Carbon filled Nylon (FDM) has excellent stiffness and good temperature resistance. Ranks between standard Nylon and continuous Carbon-fiber reinforced Nylon.
Material family
Kevlar-fiber reinforced Nylon
Kevlar-fiber reinforced Nylon (FDM) contains continuous kevlar fibers that give excellent mechanical properties and high abrasion and impact resistance.
Material family
Fiberglass reinforced Nylon
Fiberglass reinforced Nylon (FDM) contains continuous glass fibers that give high stiffness and excellent heat resistance. Ideal for high temperature applications.
Material family
Binder Jetting High strength Materials
Binder Jetting is most commonly used for full-color parts, low-cost metal printing, and large sand casting molds.
Can produce very large parts
Mechanical properties not as good as DMLS / SLM
Price $$$$$ Tolerance ± 0.2 - 0.3 mm
Turnaround time < 5 days Wall thickness 2.0 mm
Max part size 180 x 100 x 60 cm Layer height 50 - 400 μm
Stainless steel 316 (sintered)
Stainless steel (Binder Jetting) is sintered and is a cost-effective way of producing metal parts with good mechanical properties.
Properties
Material family
Stainless steel 316 (bronze filled)
Stainless steel (Binder Jetting) is infiltrated with 40% bronze and is a cost-effective way of producing metal parts with good mechanical properties.
Properties
Material family
