1. 3D printing
  2. Impact resistant
Impact resistant
High impact resistant thermoplastic parts made using the SLS or FDM printing process.
FDM Impact resistant Materials
Benefits and Limitations
Fast turnaround times
Standard ABS
ABS (FDM) has good mechanical properties, with excellent impact strength, superior to PLA, but less defined details. Commonly used for enclosure prototypes.
Properties
Material family
Standard ASA
ASA (FDM) has good mechanical properties, similar to ABS, with improved UV stability and high chemical resistance. Commonly used for outdoor applications.
Properties
Material family
Kevlar-fiber reinforced Nylon
Kevlar-fiber reinforced Nylon (FDM) contains continuous kevlar fibers that give excellent mechanical properties and high abrasion and impact resistance.
Material family
SLS Impact resistant Materials
SLS is used for both prototyping and small-batch production of functional plastic parts with good mechanical properties.
Longer lead times than FDM
Price $$$$$ Tolerance ± 0.3% (min: ± 0.3 mm)
Turnaround time < 5 days Wall thickness 0.7 mm
Max part size 75 x 55 x 55 cm Layer height 80 - 120 μm
Standard Nylon
Standard Nylon (SLS) - PA 12 - has all-around great mechanical properties and chemical resistance and is ideal for functional parts and prototypes.
Material family
Nylon 11
Nylon 11 (SLS) - PA 11 - has higher impact resistance and is more flexible than standard Nylon (PA 12), but has lower hardness.
Material family
