How a student created a 3D printed camera inspired by three cameras he couldn't afford
SHARE THIS ARTICLE
SHARE THIS ARTICLE
Paul Kohlhaussen, a student from Richmond in London has created a fully functioning 3D printed camera. Paul took the best features from an array of costly high-end cameras and reverse engineered them into the camera of his dreams. Without the funds to afford the camera he needed to get the perfect shot he wanted and no knowledge of CAD, Paul taught himself everything from scratch when designing and building the eight components that make up the camera's modular design.
247651-download--14--e7fda7-large-1495098913 A front view of the Cycloptic Mustard Monster
The project initially started as Paul wanted to start shooting larger negatives than standard medium format allowed which is possible but only on camera’s with extremely high costs or ones which had been discontinued, this paired with the affordability of 3D printing got the project started. The camera was a product design entry to the 3D Hubs Student Grant, a Grant given annually to students who show the best use of 3D printing in the fields of architecture, product design and engineering.
247646-Screen-Shot-2017-01-03-at-18.47.25-428df4-original-1495098750The assembled SLS print with lens attached, the start of post processing the parts
The camera is built to shoot 6x14 negatives on 120mm film and it’s modular eight part design allows it work easily with different camera equipment. Paul brought together the features of the $5,000+ Mamiya 7 for medium format photography, the discontinued Hasselblad XPan for the panoramic frame size and took inspiration for the design from the $5,000+ Leica M series resulting in the creation of The PK-6142016, also known as the Cycloptic Mustard Monster. Paul’s design grew from the lens he chose to use (Schneider Kreuznach 90mm Super Angulon), this gave him a starting point to create the camera around.
247647-switzerland-small-eb04b4-large-1495098751
247654-download--13--b8d525-large-1495098913Two example shots of the wide panoramic frame size you can shoot with the camera
Paul considered other technologies such as CNC and Injection Molding but 3D printing was chosen as the most cost effective and accessible means of production. SLS Nylon was used thanks to its ability to be post processed and its high accuracy, making sure the tolerances were perfect for easy assembly. Due to SLS not needing support material during the printing process, it meant different parts complex geometries could be 3D printed with a clean surface finish. To give the camera its unique look it went through various forms of post processing including sanding, a coating of automotive primer and a full cover of sealant.
247701-frierender-frank-e22cad-large-1495111659
The Cycloptic Mustard Monster in the field mounted on a stand
📍 Download our free engineering guide for 3D printing here
Paul has now launched the camera on Kickstarter so that this kind of photography is democratised and not only available to those can afford the high price point. The camera can also be adapted for different lens and film sizes opening up the door for even more creativity for budding photographers. If you would like to learn more about SLS 3D printing, you can find an introduction to the technology on our Knowledge Base.
247648-spacer-1-a34bb3-large-1495098755A top down view of the Cycloptic Mustard Monster
Check out our other Student Grant projects:
Or start applying now to the 3D Hubs Student Innovation Grant 2020. The deadline for submissions is on June 28, 2020, 23:59 CET.
