3D printing service A Coruña
FDM 3D Printing service in A Coruña
SLS 3D Printing service in A Coruña
MJF 3D Printing service in A Coruña
SLA 3D Printing service in A Coruña
Over 284 customers are satisfied with our 3D printing service.
“Everything came in a nice and safe package. Shipping was pretty fast the the print was well made. Very happy with this. ”
Cesar, Ermesinde
“GOOD WORK! Good quality and faster! 5*”
Ricardo, Porto
Standard PETG, FDM
“Super fast, good communication, everything smooth.”
Daniel, Porto
Standard PETG, FDM
“Very nice prints and really good service !”
Jorge, Arada
“Fueron super rápidos y estuvieron muy atentos al envío. Recomendable 100%”
Gonzalo, Gijón
Standard TPU, FDM
“La pieza ha servido para su diseño, flexibilidad en los tipos de envió especialmente para piezas pequeñas, Hub recomendado”
Gaspar, Lada-Langreo
“Very nice service. Top quality. Perfect communication. Excellent.”
Norberto, Coimbra
“Great Service, and the part was just like I wanted. Even to the smallest details.”
Guido, Monte Real
“Peças produzidas com muito boa qualidade e boa comunicação.”
Joao, Fatima
“Excelente profissionalismo. Servico otimo, qualidade de impressao muito boa . Muito satisfeito com o resultado final.”
Joao, caldas da rainha
“Todo perfecto y muy buen profesional. Recomendado al 100%.”
Julio, Valladolid
“Serviço impecável, tanto a nível de rapidez, profissionalismo como qualidade. Aconselho ;)”
Tiago, Portalegre
Standard PETG, FDM
“Good quality prints and high quality service”
Diogo, Lisbon
“Serviço impecável. Até melhoraram o meu modelo!”
André, Lisboa
“Excellent print quality! The turn around time was as good as it can get. If I need anything else printed I know where to go.”
Diogo, Lisboa
“Rápido, boa qualidade e o vendedor atencioso!”
Jorge, S. Domingos de Rana
“Muy gentil y disponible, impresion de alta calidad”
Giovanni, Villanueva de la Cañada
“Muy rápido, flexible y buena comunicación”
Miguel, Villanueva del Pardillo
“Fast shipping and good quality. Thank you very much.”
Carlos, Güeñes
“Excelente trabalho realizado, rapido esficaz e muito em conta. Recomendo”
Luis, Beja
“Servicio rápido y de una calidad excepcional en los resultados.”
Luis, Portugalete
“For me it was a fantastic service, very quick and top quality”
glenn, Erandio
“El servicio ha sido muy bueno. Me ha aconsejado sobre las diversas formas de impresión. Lo recomiendo.”
Fernando, Móstoles
“It has been a pleasure working with you. Many Thanks”
Carlos, Madrid
Standard Nylon, FDM
“Un servicio rápido y unas piezas con unos muy buenos acabados. Sin duda les volveré a encargar piezas!”
Juan, Madrid
3D printing locations near A Coruña
