Enclosure Design for 3D Printing: An Extensive Guide
John Wall
Learn how to optimize the design of your enclosure for 3D printing, follow a step by step guide on the design process and review the most common enclosure materials.
3D printing of enclosures allows design freedom, lets a designer print a prototype or final part in a matter of hours and is much cheaper when compared to traditional manufacturing methods. 3D printed enclosures offer an effective method of confirming form and fit and several of the materials that can be used for printing enclosures are suitable for end use applications.
Assembled 3D printed enclosure for a DIY loudspeaker
This article will discuss the most common 3D printing technologies that are used to print enclosures, methods for securing printed enclosures together and introduce some design considerations to help optimize enclosure design for 3D printing.
3D printed enclosure technologies
The table below discuss the main 3D printing technologies and whether they are appropriate for a range of enclosure applications.
Application Description Printing Technology
Rapid prototyping General purpose plastics are a cost effective and quick method of printing enclosures. FDM
High Temperature Heat resistant plastics are rated to remain stable up to temperatures as high as 80℃ after thermal post treatment. Polyjet
High quality surface finish The selection of surface finish is usually governed by cost and time. SLS nylon results in a satin-like matte finish that is slightly grainy to the touch while material jetting and SLA offer fine-detail models with very smooth surfaces. SLA, SLS or Polyjet
High accuracy SLS nylon, SLA and Polyjet printed parts are highly accurate and are capable of printing to within 0.2 - 0.5 mm. They give an excellent surface finish. SLS nylon does no require any support while the support used for Polyjet is typically dissolvable and easy to remove resulting in an smooth surface after post processing. SLS or Polyjet
Transparent 3D printed transparent plastics allow for inspection or verification of internal components and are often applied to applications where fluids are being employed. Polyjet
Flexible material Flexible enclosures allow the pressing of buttons or motion of switches through the sealed case. Rubber-Like plastics or SLA flexible resin
Securing enclosure assemblies
Snap fits, interlocking joints, threaded fasteners and adhesives are all viable options for 3D printed enclosure connections. Designing snap-fits and push-fits for an enclosure that does not require repeated opening is much easier because the joint does not have to be as wear-resistant. For quick prototypes adhesives are a quick and easy method to permanently fasten the enclosure.
Snap-fits are regularly used for securing 3D printed enclosures
Fastening with threaded fasteners is a durable and quick option for reliable repeated opening
Designing 3D printed enclosures
The design of enclosures for 3D printing typically follows 2 main steps:
1. Enclosure planning and component measurement
It can be useful to 3D model the internal enclosure components along with the enclosure to allow for easy clearance checks and to help determine the optimal component positions.
2. Designing the structure
While tolerance and clearance recommendations will vary with printer technology and calibration the bullet points below offer a set of design guideline to use:
  • A minimum wall thickness of 2 mm.
  • Reduce stress concentrations by including radii or fillets in corner and edges. Even a small radius can make a big difference.
  • Allow 0.5 mm around internal components to compensate for distortion, shrinkage and printer tolerances.
  • Add 0.25 mm to the diameter of screw and fastener clearance holes.
  • Subtract 0.25 mm from the diameter of holes if you are wanting the screw or fastener to bite into the case.
  • Allow 2 mm clearance around ports (1mm each side).
  • If your enclosure design is eventually going to be injection molded remember to use uniform wall thickness in you design.
  • Add lugs and cut outs to assist with assembly/disassembly and alignment if the enclosure with multiple parts (base & lid).
  • While ribs and gussets are critical design features of injection molding and not essential for 3D printing their inclusion can help reduce and distribute stresses throughout the part and improve rigidity. To save on material ribs and gussets can be designed to 75-80% of wall thickness.
  • Include bosses around holes in locations where threaded fasteners will be used to reduce the likelihood of bulging, distortion and potential fracture. A minimum of 5mm wall thickness around the hole is a good starting point.
Rules of thumb
  • For enclosures that will experience repeated opening and closing a wear-resistant material such as sls nylon. For rapid prototypes where form or fit are being tested FDM provides a fast low cost method of production.
  • If the enclosure will be subjected to loads include gussets, ribs and bosses to improve strength
  • A minimum wall thickness of 2mm, 0.5mm tolerance around internal components and ±0.25mm for clearance/bite holes are good start points to consider when designing a 3D printed enclosure.
John's picture
John Wall
18 year old maker of open-source wearable technology and budding entrepreneur with WΛLLTΞCH - Stanford 2020
