Standard blank sizes for CNC machining (sheets & rods)
Tables of the standard blank sizes (sheets & rods) commonly used in CNC machining.
Standard Blank Sizes for CNC machining (Sheets & Rods)
The “blank” in CNC machining is the piece of material (metal or plastic) that is initially loaded to the machine. Stock materials come as plates (for CNC milling) or rods (for CNC turning) in a variety of sizes. In the tables below we summarize the most common blank dimensions found in a typical machine shop.
Note: 0.3 mm to 1.5 mm of material will be removed from each side of the blank during machining (that is up to 3 mm total). This should be taken into account during design as the blank size can significantly increase the material cost for large-scale productions.
Plates
Stock plates come pre-cut to size or as large sheet (typically, 2 m by 1 m - 6 ft. by 3 ft.) that are cut to blanks by the machine shop. So, the limiting dimension for a plate when it comes to design is its thickness.
The table below summarizes the most common aluminum and steel plate thicknesses that can be found in the warehouse of every machine shop. For an extensive, refer to a material supplier catalog.
Thickness [mm] Thickness [inches]
3 mm 3/16''
4 mm 1/4''
5 mm 5/16''
6 mm 3/8''
8 mm 7/16''
10 mm 1/2''
12 mm 5/8''
15 mm 3/4''
20 mm 1''
25 mm 1/2'' increase therafter (up to 5'')
30 mm
10 mm increase thereafter (up to 100 mm)
Rods
Rods come as long stock (typically, 1 m - 3 ft. - or longer) that are cut to blanks by the machine shop. The limiting dimension here is the diameter of the rod.
Diameter [mm] Diameter [inches]
3 mm 1/8''
4 mm 3/16''
5 mm 1/4''
6 mm 5/16''
7 mm 3/8''
8 mm 7/16''
9 mm 1/2''
10 mm 5/8''
12 mm 3/4''
14 mm 7/8''
15 mm 1''
16 mm 1/4'' increase therafter (up to 3'')
20 mm
25 mm
30 mm
40 mm
10 mm increase therafter (up to 100 mm)
Certifications mockup for the knowledge base article
Different types of quality documentation and when you need them
Learn about the role quality documentation plays in the manufacturing process, how to obtain it, and the types of documentation that apply to parts, materials, and more
How do you deal with sharp corners in CNC machining? Designing with the machinist in mind
Have you designed your parts with sharp corners? They may look good on paper, but they're a nightmare to manufacture with CNC machining. In this article, learn how and why to avoid sharp corners in your designs. It'll reduce lead times, cost and potential headaches for machinists.
What is anodizing and how does it work?
What is anodizing? Anodizing is key to finishing parts made from aluminum and other metals. Learn how anodizing works and why it is an important part of CNC machining and manufacturing.
cnc-surface finish-as-machined-1
What are the different types of threads for manufacturing? Practical tips for engineers
What are the different types of threads for manufacturing? In this article, learn how to correctly design threads to reduce lead times and cost for your next CNC machining production run.
What is heat treatment and how does it improve CNC-machined parts?
What are the different types of heat treatment and how do they affect CNC-machined parts? This article explores how heat treatments can be applied to many metal alloys to drastically improve key physical properties like hardness, strength and machinability.
How to design parts for CNC machining
In this complete guide to designing for CNC machining, we've compiled basic & advanced design practices and tips to help you achieve the best results for your custom parts.
Standard Drill Bit Sizes for CNC machining (Conversion Tables)
Standard drill bit sizes for CNC machining
Use these conversion tables of standard drill bit sizes (metric, fractional inch, and wire gauge) common in CNC machining to reduce manufacturing costs from custom tooling.
