About SLS Nylon
It's the perfect all-rounder: easy design rules, strong and slightly flexible. Nylon allows for functional end products and complex designs. Its surface is a bit grainy, but it can be polished for a smooth finish.
Nylon prints are laser sintered on industrial 3D printers. The technology gives you a high degree of form freedom and you can even print moving parts in one go.
Example prints
SLS Nylon
  • Functional prototypes and end products
  • Complex designs with intricate details
  • Moving and assembled parts
  • Cases, holders, adapters
Limitations
  • Cavities within design (unless making use of escape holes)
Design rules to remember when printing with SLS Nylon
SLS design rule: Embossed and engraved details
0.5 MM
For embossed and engraved details, we recommend a minimum line thickness of 0.5 mm and a depth of 0.5 mm.
Tip: if you are putting text on your design, use a bold sans-serif font for readability, such as Arial Bold.
SLS design rule: Escape holes
Escape holes
4 MM DIAMETER FOR ONE ESCAPE HOLE, 2 MM FOR TWO OR MORE
As SLS Nylon is built up from powder, all the cavities in your design will be filled with powder. It’s a good idea to hollow your model to save costs and add some holes for the powder to escape.
Tip: having multiple holes makes it easier for the powder to escape, as we can carefully blow air through you model.
SLS design rule: Minimum detail size
Minimum detail size
0.2 MM
Selective Laser Sintering is one of the 3D Printing processes with the highest accuracy; up to 0.2mm is enough to create clearly visible details.
SLS design rule: Minimum feature size
0.8 MM (OR 1 MM IF CONNECTED JUST ON ONE SIDE)
The minimum feature size for printing with SLS Nylon is 1 mm. If your feature is a thin wire connected on both sides, you can go slightly thinner to 0.8 mm, otherwise we recommend at least 1 mm thickness.
SLS design rule: Moving or interlocking parts
0.5 MM CLEARANCE BETWEEN PARTS
A powerful feature of SLS Nylon is that you can have moving parts printed in one go. In order for the parts to come loose you need to keep a 0.5 mm clearance.
Tip: if you have moving parts like axles or hinges over a long distance you need to increase your clearance or create extra escape holes for the powder to get out.
SLS design rule: No supports needed
No supports needed
SLS Nylon is printed by fusing together Nylon powder with a laser. The powder acts as support material while building up your print, therefore no support structure is needed, providing you with maximum form freedom.
SLS design rule: Wall thickness
Wall thickness
1 MM (0.8 MM IN SMALLER OBJECTS)
The 3D model's wall must be thick enough to support the model. We recommend with working with 1.0mm for larger objects, in smaller objects you can have lower wall thickness of 0.8 mm.
SLS Nylon is printed using Selective Laser Sintering (SLS) technology
SLS (Selective Laser Sintering) uses a laser to shape and form extremely thin layers of powdered material by melting it together one-by-one to create a solid structure.
The advantage of this process is that the excess unmelted powder acts as a support to the structure as it is being produced which allows for complex shapes to be made and no additional supports are required.
Explore other popular materials
Fiber-Reinforced Nylon Marvin
Engineering parts as strong as aluminum for the price of plastic
Rigid Opaque Plastic Marvin
Realistic prototypes with excellent details and high accuracy.
Full Color Sandstone Marvin
Photo-realistic full color (scale) models and sculptures.
