Dimensional accuracy of ± 0.5% with a lower limit: ± 0.5 mm
Lead times from 1 business day
Get an instant 3D Printing quote All uploads are secure and confidentialWe have over 90 3D printing shops in our network and are well known for manufacturing high-quality parts at competitive prices, from rapid prototyping with Fused Deposition Modeling (FDM) to functional end parts made with Selective Laser Sintering (SLS) or Multi Jet Fusion (MJF).
Dimensional accuracy of ± 0.3% with a lower limit of ± 0.3 mm (± 0.012")
Lead times from 3 business days
Lead times from 2 business days
For more information on FDM 3D printing, read our
introduction to the process or learn
how to design better parts for FDM.
For more info on SLS 3D printing, check out our
introduction to the technology and learn
how to design better parts for SLS.
For more information on MJF 3D printing, check out our
how to design better parts for MJF.
For more information on SLA 3D printing, check out our
how to design better parts for SLA.
With over 65,000 customers from every industry, including aerospace, defense, robotics, medical, machinery, automotive and electronics, we have extensive experience meeting a diverse range of 3D printing requirements, from prototyping to production: Visual aids, concept models, injection-molding prototypes, form-fit & function prototypes, tooling and casting patterns, jigs, grips and fixtures, and durable end parts.
Upload a CAD to start (STEP, STP, IGES, IGS, SLDPRT, 3DM, SAT, STL, OBJ or X_T)
Price updates in real-time as you change materials, lead time, etc..
No hidden costs. Our instant quotes are not just indications, but the actual price, and include shipping and customs up front.
“Easy to communicate with and appears to take the job seriously. I'll likely be back for future prints when the need arises.”
“Order filled faster than expected. Easy to work with.”
“Great looking parts. My go to for critical parts”
“Best looking parts by far. Great dimensional accuracy!”
“Professional service and great product, we will be back. Thanks!”
“Thanks for sending pictures before shipment.”
“Had a redo on the print. Still was delivered quickly. Absolutely wonder job on this and all prints.”
“Bryan very quickly had my order printed and stood behind every piece printed. I mentioned a slight fitment issue that was resolved with some minor sanding and he tweaked some settings and had a new one printing before I could stop him! Great service backed by a stand-up guy.”
“Great service. Have a friend in the industry who reviewed the parts that were sent and he could not believe how well done they were. Highly recommend this hub.”
“Good parts and speed 2 time ordering and will keep ordering.”
“The prints turned out excellent! Thank you!”
“very intricate work. appreciate the work. awesome. thank you”
“Loved the turquoise color for my print. On-time as always, great quality”
“Very happy with the service. Fast turn around and the print results are excellent! I used standard resin with 100 micron layering. There is no noticeable layering. I am using this part to replace another part that was originally cast with resin using an injection molding process. I designed the replacement part in Rhino with a LOT of detail that was not in the original. This 3D part is a LOT more detailed than the one I am replacing, and it is as smooth as the original.”
“Robert was amazingly fast, parts are great.”
“FANTASTIC experience as always. Always nice to be a return customer. Will be back again!”
“Fantastic service and print came out better than expected.”
“great communication and service. i have already placed multiple order with them. thanks.”
“Thanks for being flexible with the pickup time.”
“Absolutely no complaints. This is the second time I've gotten a variation of this model printed, and this one is significantly higher quality.”
“Excellent service, precise, perfectly printed, fast turnaround.”
“You guys worked on the weekend, listened to my needs, gave great advice and got my print before my event!! Couldn't have been any better. Excellent.”
“Parts looked great - arrived right on time.”
“Excellent work– very detailed, the parts fit together perfectly, overall we are very satisfied!”
“Fast and high quality service, as always.”
We have an extensive range of online resources developed to help engineers improve their capabilities.
Milling (3-, 4- & full 5-axis), turning and post-processing
50+ metals and plastics & 10 surface finishes
Tolerances down to ±.0008” (0.020 mm)
Lead times from 5 business days
6 metals & 9 surface finishes
Tolerances down to ±.004” (0.010 mm)
Wide range of part complexities and sizes
1 to 1M parts
