3D printing service Quebec City
FDM 3D Printing service in Quebec City
SLS 3D Printing service in Quebec City
MJF 3D Printing service in Quebec City
SLA 3D Printing service in Quebec City
Over 243 customers are satisfied with our 3D printing service.
“Benjamin was very diligent and sharp with the print order. Even when I was a bit slow on the answers myself, he was very patient and did everything to get my order done faster. I strongly recommend!”
Gabriel, Ville de Québec
Standard TPU, FDM
“Blazing fast service and great print quality. Service hyper rapide et impression de qualité. ”
Francois, Québec
“Great response,communication and speed. Very accommodating as well!”
André, Québec
“Very fast and good communication ! Très rapide et très bonne communication ! ”
Stéphane, Québec
“Printing quality was better then I expected. I was able to easily reach to schedule pick up.”
Diego, Saint Romuald
“Amazing job and very professionnal service... ”
Jean-Francois, Quebec City
“Excellent Service and very flexible on demands. ”
Canada, L'Islet
Tough resin (ABS-like), SLA/DLP
“Just a little problem with the shipping but it's only the fault of Fedex”
patrick, sherbrooke
“High quality print and great service, as usual :)”
Marc-Andre, St-Cesaire
Standard PETG, FDM
“Amazing, super fast :) Quality on the top! ”
Sumire, Notre-dame-des-Prairies
“Excellent quality of the print and the finishing. Communication was easy. ”
Eric, Saint-Bruno
“Awesome, fast service! Thanks a lot, I will order again!”
patrick, Saint-Jean-sur-Richelieu
Standard PETG, FDM
“The product is perfect and the service is awsome”
Christian, Saint-Hubert
Standard resin, SLA/DLP
“Outstanding service. He was able to print a huge batch of parts overnight and they were flawless! 10/10 ”
Diego, Saint-Lambert
“Excellent communication. Highly recommend. ”
Marc-Antoine, Montreal
“Love that guy ! Insane service , fast and the quality is perfect. Thanks”
Josef, Montreal
“Quick response with a very good printing quality.”
Michel, Montreal
“Very good print for the price and pretty fast turn around.”
Gabriel, Montreal
“The quality of the printing is really good,far better than any other service I used.Thank you :)”
S M Asif, Montreal
“Overall, the service was great & fast. I definitely consider ordering more parts to your company in the very near future!”
Radin, Montreal
Clear resin, SLA/DLP
“Quick turnaround. Easy communication. Would use again! ”
Dan, Montreal
“Thank you, the part is accurate & the service is really fast.”
Marie-Josée, Montreal
Carbon filled Nylon, FDM
“Awesome. Will get all my repeat business.”
Dan, Montreal
“Fantastic service and great quality prints. Thank you. ”
Alex, Montreal
Standard PETG, FDM
“Parts were completed quickly and appear to be good quality.”
Steven, Montreal
Standard TPU, FDM
