3D printing service San Jose, CA
FDM 3D Printing service in San Jose, CA
SLS 3D Printing service in San Jose, CA
MJF 3D Printing service in San Jose, CA
SLA 3D Printing service in San Jose, CA
Over 267 customers are satisfied with our 3D printing service.
“He was great, and the print turned out excellent! I highly recommend!”
Phoenix, San Jose
“Thank you for letting me know about the bad file!”
Chris, San Jose
“Service provider was extremely responsive and shared pictures of the print before he shipped it. Print arrived very fast and well packed. The print came out exactly as intended, couldn't be happier with my experience!”
Kevin, San Jose
“Excellent service, part was just as I expected. Thanks.”
Paul, San Jose
Standard PETG, FDM
“Looks great! Follow up order coming quickly. Thanks!”
Kevin, San Jose
“Print was finished early and the quality was superb!”
Aidan, San Jose
“Very helpful, printed super fast and turned out great. Thanks!”
Rianna, San Jose
“Beautiful prints. Will order again. Thanks.”
Marc, San Jose
Standard TPU, FDM
“Great job with a small print! Will go back for further iterations.”
Austin, San Jose
“Excellent speed. Good quality. Delivered timely.”
Sergey, San Jose
“good price. quality print. and shipped quickly. i had a nintendo switch dock printed. all parts came as described and to spec.”
carlos, San Jose
“Got the parts I needed at reasonable cost in a couple of days. What's not to like? ”
Stephen, San Jose
“Great result, very professional service, with high sensitivity to my quality and turn-around requirements. Offered technical advice as well. Great hub to do business with!”
Vincent, San Jose
“Everything was excellent. Will be using this service again...soon!”
Chris, Campbell
“Nice prints, flexible with support placements!”
Tina, San Jose
Standard resin, SLA/DLP
“Parts are durable and fancy. The surface was so smooth. This service provider has the best quality that I know. ”
Xuwen, San Jose
“Quick turnaround and very convenient pickup! Overall, a flawless transaction. ”
Alan, San Jose
“Print quality is good. Response and delivery are speedy. Reliable shop.”
Sukwon, Milpitas
“Alex provides consistant good quality and provides extra effort to assure good results”
Karl, Milpitas
“From a fellow printer to another, Great Job! ”
Stefan, San Jose
“Great work! Thanks. These are really tiny parts and glad that you could have it done..”
Nakul, Sunnyvale
“Turnaround was super fast. Good communication.”
Tony, Sunnyvale
“perfectly done, I couldn't have asked for better.”
Robert, Sunnyvale
Durable resin (PP-like), SLA/DLP
“Fast turnaround and prompt replies. Good service.”
Jeremy, Sunnyvale
Standard Nylon, SLS
“He sent in-progress pics, which were very nice to see. He had a large selection of colors and was very knowledgeable and great to work with.”
Vijay, Sunnyvale
Standard PETG, FDM
