3D SYSTEMS PROJET 3510 HD PLUS (2 AVAILABLE)
AND
3D SYSTEMS PROJET 3510 HD MAX
JUST MAINTAINED, FULLY TESTED AND WORKING
PRICE IS 12,000$ + SHIPPING (PRICE IS PER EACH PRINTER)
DISCOUNT PRICE FOR ALL 3 PRINTERS
Description:
The ProJet® 3500 series of plastic 3D printers are ideal for creating durable, high-definition functional prototypes,
rapid tooling such as injection molds and casting patterns, and end-use parts right in your office.
This versatile range of workhorse printers is easy to use, with fast print times and easy post-processing.
Parts made on ProJet 3500s are beautifully precise, with sharp edges and true-to-CAD fidelity.
Net Build Volume (xyz) – 11.75 x 7.3 x 8 “ (298 x 185 x 203 mm)
Resolution
HD Mode – 375 x 375 x 790 DPI (xyz); 32μ layers
UHD Mode – 750 x 750 x 890 DPI (xyz); 29μ layers
XHD Mode – 750 x 750 x 1600 DPI (xyz); 16μ layers
Accuracy (typical) 0.001-0.002 inch per inch (0.025-0.05 mm per 25.4 mm) of part dimension.
Electrical 100-127 VAC, 50/60 Hz, single-phase, 15A; 200-240* VAC, 50 Hz, single-phase, 10A
