hi, I’ve had this printed twice. The first time in ABS I liked the strength but for its use it was too plastic so the tool it is used to hold would occasionally slip out. So I tried it in generic TPU as seen in the photo. I thought this would have some rubber grip and stop it from slipping out but the arms ( the bit with the teeth) flexed to much and once again the tool slipped out. Ideally I am needing a stiff rigid filament that also feels like rubber and together this should hold the tool in place. The photo shows one side that sits in a tool belt and then the other side hold the steel tool like a tray. I would greatly appreciate any suggestions. I don’t print myself but use printers on 3D hubs but need to know what the next filament I should try so I can post a new job.
