Like new, rarely used with original packing. Item sells in bundle with battery for field work a leather strap for the battery, 2 data cables for the scanner, power cord for the scanner.No scratches or any other damage
GENERAL SPECIFICATIONS
*3D resolution, up to 0.5 mm
*3D point accuracy, up to 0.1 mm
*3D accuracy over distance up to 0.03% over 100 cm
*Colors:24 bpp
*Texture resolution: 1.3 mp
*Scanning technology: structured light
*Structured light source: flash bulb (no laser)
*Working distance: 0.4 – 1 m
*Linear field of view: HxW @ closest range 214 × 148 mm
*Linear field of view: HxW @ furthest range 536 × 371 mm
*Angular field of view: HхW 30 × 21°
*Video frame rate: up to 16 fps
*Exposure time: 0.0002 sec.
*Data acquisition speed: up to 2 mln points / sec.
*Multi core processing: Yes
OUTPUT FORMATS
*3D formats: OBJ, PLY, WRL, STL, AOP, ASCII, Disney PTEX, E57, XYZRGB
*Formats for measurements: CSV, DXF, XML
COMMON SPECIFFICATIONS
*Weight: 0.85 kg (1.9 lb)
*Dimensions: HxDxW 262 × 158 × 63 mm
*Power consumption: 12V, 48W
*Interface: 1 × USB 2.0, USB 3.0 compatible
*Processing capacity: 40 mln triangles / 1 GB RAM
1’m Asking $8500 for it (Quick to sell), Contact me at Renlaz@pm.me for pictures.
