which is the best scanner and Printer all around the world ??? can any one suggest me
@veeru_machani Hey there! What exactly you want to achieve with your printer and Scanning? You can use this guide to see which printer fits you the best :slight_smile: And scanning just depends on what you want to scan with it and what is your budget.
Let us know what are you looking for? :wink:
You need to know what you want to do with your scanners and printers, this question is like asking what is the best vehicle? It could be a spaceship, could be a motorcycle, could be a boat. Where are you going with it?
i want to print ones figaurines models >>>\
If you want to print colored (textured) figurines, then there aren’t too many options. For a low cost solution, try Sense from 3DSystems. The quality of data is not great, but it’s very inexpensive (under 500 pounds). If you want something of higher quality, there is the Artec Eva scanner or the Thor3D scanner (http://thor3dscanner.com/3d-scanner-thor/). Both are between 10 and 20K. There is also the Creaform GoScan, but that’s even more expensive.
As for printers, for a long time there was only one option - 3D Systems Z printer 650 (or now 660) (http://www.3dsystems.com/3d-printers/professional/projet-660pro). But that is quite pricey. Now I’ve seen some similar printers coming out from Asia (http://3dpandoras.com/) for a fraction of the cost, but those companies are start ups…so I’m not sure the quality of the print is very good yet. I would probably wait another year before purchasing those. They need sometime to get the kinks out.
