anyone know of a technician who could help us unjam it? Thanks
Were do you live?
There are no 3D printer technicians for FDM 3D printers, it’s a DIY community. I have 2 craftbots and when they clog I heat up an Allen key the same size as filament and push it through the top. You have a clogged nozzle which is common and relatively easy to fix. If you have question go to craftbots forums.
It’s a pretty easy process to follow and you don’t really need special tools or equipment. As mentioned by @Gear3D the community already described all the steps to achieve it on the Craft Unique forum :wink:
BTW: of course there are technicians to do some work at the CraftBot: most resellers -like me- are capable to replace and solve all problems. Also because of having all spare parts by hand.
I just posted a link with a photo manual how to unclog the hotend of the CB, but it has to be approved by the admin because of the links in it.
But clogs can be solved by:
- pushing with a hex key as gear3D suggests.
- replacing // unclogging the nozzle itself (heating the hotend and unclog with a 0.4mm drill or unscrew the nozzle while heated and replace it with a new one (or burn it clean). Be careful to hold the hotend while unscrewing the nozzle as turning will break the heater cartridge wires.
- removing a clog in the heatsink of the hotend (that’s my post about).
Maybe you can google search for that post with:
CraftBot: Disassembling a Complete Clogged Extruder
Bart
Hello. Have you tried the Craftunique forums? Lots of help there. You could also email Craftunique and I’m sure they will give you some advice. Try the forums if you haven’t. Very friendly and helpful advice there.
Please visit the unclog video https://craftunique.com/videos. If you need more help please email support@craftunique.com with a picture of your serial number.
