Hello everyone i want to know wich resins i can use on my Form1+ because i want to make a dental plates, dental shells and provisional parts.
Im using at this moment the Castable resin from Formlabs but it isn’t that hard how i think it was.
Thank you.
Hi Derius,
I am not an expert for your bussines so all I can suggest is to try postcure your prints if you haven’t already.
I have never tried a castable resin yed but I believe it could also be hardened with postcuring on direct sunlight or in UV oven.
Hi. I have a Form 1+ and use the castable resin regularly. I developed my own casting setup in my garage which has been very successful when using the 3D printed castable parts. As was mentioned earlier, you do need to UV post-cure the resin after printing (about 2 hours in a UV oven). There are multiple ovens available online if you are willing to spend some money. What I ended up doing (because of my DIY nature and lack of money) was to build a simple box and put inside some 405nm LEDs. I can document my design and fabrication if you would like. After the post-cure, it is sufficiently hard for handling and casting. I am assuming that you are using the resin in a casting setup? Hope that helps.
Paul
