USD$1300
All reasonable offers will be considered! I just want it put to good use somewhere else.
I bought the printer in 2015 for a few specific R&D projects. These are now completed so I haven’t used it for the last 2 years. I removed the print bed and cleaned it but have not yet installed the now print sheet (included).
I also have the flexy-dualy print head to print both flexible and rigid material at the same time.
Finally, also included is a heat box built to help keep temperature stable. It actually makes a difference in terms of print quality, especially for bonding the separate layers.
Located in Ottawa, ON. Still have the original packaging shipping (at buyers expense) if necessary.
Generic description below:
The Lulzbot Taz 5 is an open source 3D printer for the tinkerer. It comes with a metal frame, heated build platform and has an exchangeable extruder system. Due to its active community many customizations are available online. It supports materials like PLA, ABS, HIPS, Ninja Flex and many more.
PRINTER TYPE FDM MATERIAL ABS, PLA, HIPS, PVA, Bronze, Copper, Wood, Polyester (Tritan), PETT, Polycarbonate, Nylon, PETG, conductive PLA and ABS, UV luminescent filaments, PCTPE, PC-ABS, Alloy 910 BUILD VOLUME 29.8 x 27.5 x 25 cm MIN LAYER HEIGHT 50 microns MAX LAYER HEIGHT 500 microns EXTRUDER HEAD 1, 2 (optional) PRINTING SPEED 200mm/sec OPEN SOURCE Hardware & software CAN YOU USE 3RD PARTY MATERIAL? Yes HEATED PLATFORM Yes FILAMENT DIAMETER 3.00 ON-PRINTER CONTROLS Yes CONNECTIVITY SD card
The printer was used for a specific project that was completed and I no longer need it. In really good condition. Comes with standard head, optional FlexyDually head and a custom made heat box for improved print quality (temp stability).
$1300 obo
