This cute little truck was created by designer JakeJake.
Truck body and suspension prints in one piece. No need for support, they are built into part. Rim caps friction fit to body, no glue is needed. This one has been printed on a Ultimaker 2.
For a two-tone wheel ring, 19.8 mm is the appropriate height to swap filament if you are using a plugin to pause it.
You can download it for free here: https://cults3d.com/en/game/mini-monster-truck-with-suspension
That’s awesome! Do you the wheels turn?
That’s so cool! I bet if you used some flexible filament on the wheels it would be even more fun.
Thanks for him, the designer is JakeJake. No, unfortunately the wheels don’t turn.
Great idea, you’re right! Someone also said (on reddit) to add googly eyes on it :smiley:
Turn laterally/side-to-side or rotate? Because I’m sure they rotate. :slight_smile:
