I have an objet30 pro that had a hard disk failure. unfortunately I don’t have the means to get professionally repaired and I was wondering if someone had experience with replacing the hard drive.
Thank you
Hey,
I don’t have too much experience when it comes to a hard drive malfunction on an object30 pro but there is possibility to get it repaired. Best option I can think that may work on the assumption that it is a hardware problem and not software is to buy a fresh hard drive and mirror the drive. For a backup set up a backup drive under Raid 1 so that way if one fails the backup can restore the original and can save you a a lot of time then dealing with customer support with Stratasys (Just Saying)
