I’m designing a Rapala lure prototype and I need to stick together two half parts of it but I’m wondering which glue to use
the wall tickness is thin ( around 1.75mm ) so my fear would be a melting and the strengh of the bonding too even if for that I’m going to use an additional system by using a special shrink tube who shrink immediately with boiling water
Thanks by advance
Hi!
Could you post some pictures of the two halves?
Since this is a small part, I’m curious as to the reason you had it printed in two haves?
I place inside 3 tungsten cylinders so I can’t make it in one part; my dream lol!
BLACKBIRD%20LOW%20TECH%20%20%20%20LEFT|690x373
Sorry, the photo hasn’t appeared. Could you provide a link?
Since the part is nylon and therefore I can’t recommend melting to fuse the parts together, maybe some sort of epoxy would work here?
