I wanted to ask if someone could help me out with modeling a wheel for my rotary encoder. I recently bought a rotary encoder an I am in need of wheel attachment. Although the supplier also has wheels that could be attached to it, none of them fits my required measurements. I would require a wheel that is similar to the one in the picture. With the difference that the surface of the wheel should be flat, not rounded. it does not have to be the exact copy of the picture. I was thinking of something similar to an open cylinder, where the side that is attached to the rotary encoder and the hollow cylinder part is facing away from the encoder.The dimension I need it in are:
Diameter: 10 cm
height: 3 cm
The construction needs to be fairly light but strong enough to withstand the force of a common house-mouse running on it (ca. 30-40g)
thank you in advance for your help
Have you solved? Because I can help you.
Pino
