Karzin
1
So I’m using a MK8 extruder on a DIY prusa rework. and whenever i try to print, i get the firs layer perfectly, however the second layer and every other layer from there will barely extrude it looks like the filament stops moving and i get these really thin threads with some lumps every now and then.
I cant figure it out, I’ve changed the steps/mm I’ve changed the heat breaker tube, the hot end, the nozzle, I even replaced the extruder with the E3Dv6 which worked exactly the same, but the filament would get stuck every time after an attempt to print.
here are some of my settings:
speed 40mm/s, retract 2 mm, nozzle 0.4mm, first layer temp. 215/60 other layers 210/60, layer height .first layer height 0.4mm
please help me, Ive been stuck on this for about two months now.
Layer height is too much to start with. 70-80% of the nozzle is max recommended. Run with .2 layers to get going.
I am assuming PLA based on temps which are ok if not a bit high.
Retraction might be a bit high try about 1.2 at 1800mm/min.
You say the first layer is good but then the rest are bad. That is a clue, something changes but what?
I still think if you are running a .4 layer that is the first thing to change.
Make one change at a time and see what happens.
