what this error means and how I can fix it
best regars
Hello Jesus,
This is taken from P-Class Error List for the uPrint:
Category 14: Controller board aborted causing shutdown
64: Find home failed, Y EOT tripped
67: Head Temperature too high
I would leave the machine shutdown to cool & then re-start. If it happens again you’ll need to speak to a service engineer to check it out.
kind regards
Ian Carter
Impossible Creations
Thanks Ian
is kinde of suport side dont heat and material side goes to hi!!
There can be a way to fix some damage connection takein the toggle head out and check for some disconected or unweld part!!!
Is this usual problem?
best
Service guide attached. Error code 14.67 Abort : Head temperature too high
1. Verify the TC and Liquefier Heaters are plugged in properly.
2. Check umbilical is connected properly.
3. TC Amp board is bad. Replace TC Amp Board.
4. Head Board is bad. Replace Head Board.
5. Replace the umbilical cable.
docslide.us_uprint-and-uprint-plus-service-guide.pdf (7.35 MB)
Griffin
6
This error can occur if you had a major material jam and enough material spooled up into the head to damage the thermocouple.
Alternately the thermocouple can fail or the amplifier board could be the problem.
I think i may may have a spare head for a uPrint. Feel free to message me if you need help working through these errors.
Mr Griffin
thanks, yes now I know checking continuity on the connetions that go to the heat, apparently is the support resistor
snd yes , the marerial is jam in al over that
what do I do next
thanks and best regards
Griffin
8
Please send me a message and I will do my best to assist.
help@SolidDetail.com
