The weight of the pieces I need to make is crucial. Where can I find the densities of various 3d printed materials?
Hi there! Usually the density is mentioned in the data sheet of the material. This data sheet should be published by the reseller. Otherwise you can look up the density on Wikipedia, if you know the material. For example Nylon is called Polyamide in chemistry and you could look up the density if Polyamide. The normal density is around 1-1,3g/cm3 The density is higher for special colors, but this is usually neglectable. Can you tell me what material you want to use for printing? you could try to use lower infill to modify the weight. If lower infill results in too weak parts you could switch to very strong material. Cheers, Marius Breuer
