According to this full spec sheet, Maximum printing size of Xeed are
1. Build size single extruder (DWH) 220 x 280 x 230mm 8.7 x 11.0 x 9.1 inch
2. Build size dual extruder (DWH) 220 x 250 x 230mm 8.7 x 9.8 x 9.1 inch
Even though I definitely choose a single extruder in simplify 3D, I can print only 220 x 250 x 230mm.
Am I doing something wrong with setting in Simplify 3D?
Are there any other people who experiences same issue?
Did you select one extruder (Left or right) or both extruder in the settings!
YES I’m sure I chose Right or Left extruder
Yoshi,
Can you manually change the wide ( under > tab>g-code>build volume)
the Std function is probably not working fine
YES I know i can change width under Gcode, but that’s not issue.
Even if i set width 220 x 280 x 230mm 8.7 x 11.0 x 9.1 inch and choose a single extrude printer cut the end of printing object.
Basically I can print only 220 x 250 x 230mm 8.7 x 9.8 x 9.1 inch with single extruder
I’m looking for some people who uses Xeed and if they have same issue or not.
Maybe just spec sheet is wrong.
did you ask for support by Leapfrog?
