I was testing a print set up on my xyz PRO 1.0, when the filament jammed. It extruded fine when i loaded the cart, but wouldn’t print to start a brim. In attempting to disconnect the extruder, I broke the quick release assembly that rests just above the extruder body. (Hulk Smash) The assembly screws into place on the carriage, has a rubber grommet that accepts the bowden tube, a spring loaded lever with a catch to hold the extruder assembly on the carriage, and a piece to hold the bowden fitting. Does anyone know of any .stl files that I could use to print a replacement? I included images of my non- broken printer to clarify.
