Anet E10 won’t print
Hi
im having trouble with my anet e10 printer
the extruded seems to move correctly but the filament is just not being fed into it
the gear just seems to move back and forth .
is there anyone who can help?
it wont let me upload a video, but the hot end was at the correct temperature
i tried moving the gear closer but it doesnt seem to work
i was told it might be a setting problem
but im not sure
I will try to swap the motor cable with other motor to rule out the connection problem. I don't think it is a setting problem.
Replace stepper & cable if no avail then new board.
Was hotend heated? Was the set screw loose on the gear? Have you tried a different motor cable from other motor?
Not the answer you’re looking for? Ask a new question to 480 ANET 3D experts active on Talk.
