Internal structure only visible in layers, Cura
Using 3DSMax, I pro booleaned a sphere inside a box. It looks fine in Max. In Cura, when viewed as solid, it is fine but when viewed in layer mode there is an internal structure that doesn't show up anywhere else. As it doesn't show up in Max there is no way I can fix it. Has anyone else had this problem, internal structure that only shows up in layer mode?
What kind of structure are we talking about? Could you share a screenshot?
Could it be that you are referring to the infill pattern? Cura fills the body with a diagonal rectangular pattern to save material and printtime.
Not the answer you’re looking for? Ask a new question to 81 Cura experts active on Talk.
