Plastic oozing thorugh hot end
I want to make sure that the problem here is the assembly, before I take anything apart. I think I might've not screwed the bolt that connects the hot end to the extruder correctly, and it lets the plastic ooze out. Has anyone had the same problem?
This is due to the nozzle not being tight enough against the heat break inside the hotend. Once it's at temp, you might notice that you can tighten it a bit more.
I hope this helps!
Best,
Maddie - 3D Hubs
You may want to revisit the install/assembly instructions for that hot end.  Typically once the nozzle is installed you would heat it and snug it down.
