Problems with printing
Something shown down below happens to me. What can be causes of this hapenning? I use a coropad, my davinci pro 3in1 is calibrated well, I use ABS on 240 degrees nozzle and 90 degrees bed; I also have my printer closed completely. If any more details are needed just ask I will try to do my best.
I use a glass bed on my da Vinci Pro 1.0 with aquanet hairspray (purple can) after cleaning the glass with rubbing alcohol.  I print about 230 with ABS on the 90 degree bed.  Depending on what slicer you are using, if you can have the first layer print at 85% height so it's pressed into the bed a little more.  I have great luck with glass beds on all my printers.  Hope this helps!
i use the xyzware for pro and i dont really think it is in there but is there any slicer that provides such a thing and also works with my printer and also is for free?
try putting some glues stick on the printbed or rise it to 95c
well glue stick on coropad is not the best idea i think as it is not soft like aluminum or glass and i cant rise the temperature further - 90 is max
Probably need to go hotter on the bed and make sure it is extremely clean.
the thing is that 1st 90 degrees is max and 2nd i always clean it very precisely (with wet paper and then with some alcohol to unfatten it
The temp is really the most likely issue.  Larger parts in ABS are really going to need a hotter bed to not warp or lose adhesion.
well i cant go further than 90 so yup
Well then!  If you are maxed out on the temp then maybe work with more brim.  Make it wider and maybe 3-5 layers thick.
you mean the brim 3-5 layers? i dont have that option in my slicer so maybe you have one that is free and provides some useful options? (i use the xyzware for pro so i guess its not so good ;/)
I am not familiar with that slicer but there is not the option to have more than on layer for a skirt or brim?
Slic3r and Cura are two popular free ones.  You may need to google a bunch to get setups and configurations going ok though.
well there are no such options in mine so i will definately try out slic3r as i have heard that it is good
Not the answer you’re looking for? Ask a new question to 958 XYZprinting experts active on Talk.
