Proper infill settings
Hello, I was trying to print a whistle the other day using Cura. The product description stated that the infill percentage didn't really matter, but he printed with 100% infill. I didn't want to use as much material so I set it to 80%. But when it started printing, my Anycubic i3 Mega printer started filling in the designed holes and extruded cuts of the model that are necessary in its sound functionality. I suspect it was an infill issue, but I'm not for sure. How do I fix this so that the holes are not filled in?
This is the model
https://www.thingiverse.com/thing:1179160
Can you take a shot as to how it printed out?
It may be that you have printed it with supports turned on.
This is a good thing, but it will mean you will need to break, or strip out the supports when the print is finished.
Best example ever...
Not really that familiar with Cura but look for a setting that is something about making the model solid or merge all outline to solid model.
-2
Hi, This is good Model I have checked and looks very useful printer. By the way, If you are freelance writing job seeking in Denver here https://freelancewriting.biz/denver/ you can easily register and started the freelance job with our clients.
