Retraction on FlashForge Creator Pro
Hello,
I'm having some issues trying to Print PVA with PLA in my dual extruder Creator Pro.  I've attached a screenshot of my speed and retraction settings as well as temps.  I'm using a black masking tape on the print bed, because that's the only tape I have that the PVA will stick to.  It won't stick to the factory bed.
Anyways.  Let me know what you think.  My issue is that this setting works perfectly for the PVA, but the Right Extruder (PLA) still oozes while the Left is printing the supports, which results in an additional support structure outside my object.
I'd love any help you can give.  I've spent probably the last 2 hours messing with print settings and such to try and nail this down.  I'd love to print with PVA since it's water soluble but it's like going 2 steps forward 1 step back with this stuff.
It's MatterHackers brand PVA filament with the FlashForge brand PLA.  When I print with just PLA this thing prints phenomenally.  Can't complain.  I love this printer.  I just can't nail down the PVA stuff.
Thanks,
T.
If you have just spent 2 hours on this, I would have been surprised if you had already figured out the right settings to use.
I don't have a Flashforge, but have other dual-nozzle printers and after trying, I still don't get satisfying results with PVA or similar support materials.
Last I tried was the new Helios Support from Formfutura and although it looks promising, I am not ready playing with it yet.
I Always seem to get either cross contamination of filaments or, if the print reaches any significant height, problems with the support to staying where it should. As I often have prints that take 30 hours or more, I'd love to have a PVA-based support solution that I can apply to such prints without having to worry, but alas, have not yet achieved that.
Yeah I created a small rectangular object and would get about 2% into the print before cancelling it and changing the settings again.  I'm using FlashPrint so I could try to use something like Simplify 3D since it seems to be a more diverse of a program.
Problem is that there is only so much that retraction can do.  When it retracts some filament back from the nozzle all you are doing is relieving the pressure in the nozzle.
This will help to reduce/stop the oozing for the most part but it may never completely stop it.
One thing to look into is adding tool change commands.  You will probably want to add one to let the PVA cool slightly while not being used then to heat back up when it is time to use it.  PVA lives in a very narrow temp range and if it sits at the upper end of that for too long it will cook in the extruder and jam.
You could also do that for the PLA and have the extruder move off the print while it cools and heats.
Hi @Rkitekt01, probably not the most helpful comment, but I never got my FF Pro to work successfully as a dual-material machine, no matter what I tried, the ooze always got in the way.  I tried towers, ooze shields, fiddling with layer by layer temperatures, the lot.  I got close to something usable, but never good enough for customer work.  Worse, PVA was the hardest to work with, got nowhere with that at all.
Hopefully someone else will come along with a solution and we'll both be happy!
yeah, I'm using FlashPrint and I'm considering switching to Simplify 3D or some other slicing software.  It feels as though when I set the retraction it only affects the Left Extruder.  I will try to contact FlashForge Support and see if they have any ideas.  But with Retraction turned up like crazy the Left Extruder prints really really well and doesn't ooze.  While the Right Extruder constantly puts out filament.  Even at 200 C the PLA still flows out of the right extruder regardless of whether it's the one actively printing.
But you're right about the PLA Support material - the linear supports were extremely flexible which wouldn't make for very good supports higher up.
I normally print PLA out of both at 210, and 0.08 mm layer height.  Creates really good prints but the PLA supports require a good bit of post work with sand paper and files sometimes.. But if I can't figure out the PVA stuff then I guess I'll just have to keep printing things in halves and pieces rather than one solid object with PLA.
-2
Notre equipe est un producteur unique de faux documents de qualite.
Nous n'offrons que des faux passeports, des permis de conduire, des cartes d'identite, des timbres et d'autres produits originaux de haute qualite pour un certain nombre de pays comme:
Etats-Unis, Australie, Belgique, Bresil, Canada, Italie, Finlande, France, Allemagne, Pays-Bas, Espagne, Royaume-Uni. Cette liste n'est pas complete.
Pour obtenir les informations supplementaires et passer la commande, visitez notre site Web:
http://www.buysellfakepassport.cc www. buysellfakepassport.cc
>> E-mails de contact:
Support general: support@buysellfakepassport.cc
Support technique: tech@buysellfakepassport.cc
Mots cles:
obtenir de faux passeports,
obtenir des passeports de nouveaute,
obtenir un faux permis de conduire,
obtenir un permis de conduire de fantaisie,
obtenir des passeports diplomatiques,
acheter de faux passeports,
acheter des passeports de nouveaute,
acheter un faux permis de conduire,
acheter un permis de conduire nouveaute,
acheter des passeports diplomatiques,
vendre de faux passeports,
vendre des passeports de nouveaute,
vendre un faux permis de conduire,
vendre un permis de conduire de fantaisie,
obtenir une licence de pilote de nouveaute,
acheter de faux passeports argentins permis de conduire carte d'identite en vente en ligne
acheter des faux passeports australiens permis de conduire carte d'identite en vente en ligne
acheter acheter autrichien faux passeports permis de conduire carte d'identite en vente en ligne
acheter des faux passeports belges permis de conduire carte d'identite en vente en ligne
acheter des faux passeports bresiliens permis de conduire carte d'identite en vente en ligne
acheter des faux passeports bulgares permis de conduire carte d'identite en vente en ligne
acheter des faux passeports canadiens permis de conduire carte d'identite en vente en ligne
acheter chinois faux passeports permis de conduire carte d'identite en vente en ligne
acheter des faux passeports cubains permis de conduire carte d'identite en vente en ligne
acheter des faux passeports chypriotes permis de conduire carte d'identite en vente en ligne
acheter des faux passeports tcheques permis de conduire carte d'identite en vente en ligne
acheter des faux passeports danois permis de conduire carte d'identite en vente en ligne
acheter Republique dominicaine faux passeports permis de conduire carte d'identite en vente en ligne
acheter des faux passeports equatoriens permis de conduire carte d'identite en vente en ligne
acheter des faux passeports estoniens permis de conduire carte d'identite en vente en ligne
acheter faux passeports finlandais permis de conduire carte d'identite en vente en ligne
acheter des faux passeports francais permis de conduire carte d'identite en vente en ligne
acheter des faux passeports allemands permis de conduire carte d'identite en vente en ligne
acheter faux passeports grecs permis de conduire carte d'identite en vente en ligne
acheter de faux passeports hongrois permis de conduire carte d'identite en vente en ligne
acheter des faux passeports islandais permis de conduire carte d'identite en vente en ligne
acheter des faux passeports indiens permis de conduire carte d'identite en vente en ligne
acheter faux passeports indonesiens permis de conduire carte d'identite en vente en ligne
acheter irlandais faux passeports permis de conduire carte d'identite en vente en ligne
acheter de faux passeports israeliens permis de conduire carte d'identite en vente en ligne
acheter des faux passeports italiens permis de conduire carte d'identite en vente en ligne
acheter des faux passeports japonais permis de conduire carte d'identite en vente en ligne
acheter des faux passeports coreens permis de conduire carte d'identite en vente en ligne
acheter des faux passeports lettons permis de conduire carte d'identite en vente en ligne
acheter des faux passeports lituaniens permis de conduire carte d'identite en vente en ligne
acheter des faux passeports luxembourgeois carte d'identite de permis de conduire a vendre en ligne
acheter faux passeports malaisiens permis de conduire carte d'identite en vente en ligne
acheter de faux passeports mexicains permis de conduire carte d'identite en vente en ligne
acheter faux passeports monegasques permis de conduire carte d'identite en vente en ligne
acheter des faux passeports neerlandais permis de conduire carte d'identite en vente en ligne
acheter des faux passeports Nouvelle-Zelande permis de conduire carte d'identite en vente en ligne
Acheter des faux passeports norvegiens permis de conduire carte d'identite en vente en ligne
acheter des faux passeports philippins permis de conduire carte d'identite en vente en ligne
acheter des faux passeports polonais permis de conduire carte d'identite en vente en ligne
acheter des faux passeports portugais permis de conduire carte d'identite en vente en ligne
acheter de faux passeports roumains permis de conduire carte d'identite en vente en ligne
acheter faux passeports russes permis de conduire carte d'identite en vente en ligne
acheter en Arabie Saoudite faux passeports permis de conduire carte d'identite en vente en ligne
acheter des faux passeports Singapour permis de conduire carte d'identite en vente en ligne
acheter des faux passeports slovaques permis de conduire carte d'identite en vente en ligne
acheter des faux passeports slovenes permis de conduire carte d'identite en vente en ligne
acheter des faux passeports sud-africains permis de conduire carte d'identite en vente en ligne
acheter faux passeports espagnols permis de conduire carte d'identite en vente en ligne
acheter faux passeports suedois permis de conduire carte d'identite en vente en ligne
acheter faux passeports suisses permis de conduire carte d'identite en vente en ligne
acheter Taiwan faux passeports permis de conduire carte d'identite en vente en ligne
acheter des faux passeports thailandais permis de conduire carte d'identite en vente en ligne
acheter de faux passeports turcs permis de conduire carte d'identite en vente en ligne
Acheter Emirati faux passeports permis de conduire carte d'identite en vente en ligne
acheter des faux passeports britanniques permis de conduire carte d'identite en vente en ligne
Faux passeports americains permis de conduire carte d'identite en vente en ligne
-2
>> E-mails de contact:
Mots cles:
-3
>> E-mails de contact:
Mots cles:
