What are the post-processing methods and steps for SLS and MJF 3D printing? In this article, we explore the most common post-processing methods, including dyeing and metal plating.
Selective laser sintering (SLS) and Multi Jet Fusion (MJF) are exciting and robust 3D printing technologies capable of manufacturing accurately detailed and complex parts without the need for support material. In general, parts produced via SLS and MJF are fit for end-use, though applying a post-process to your parts can elevate their overall quality in many respects.
There is a wide range of post-processing techniques and finishes available for SLS and MJF 3D printed parts. Manufacturers often add coatings to SLS parts in particular to improve their performance. As well, adding a functional coating can sometimes help to compensate for the lack of feasible material grades available to SLS and MJF.
In this article, we’ll cover the most common post-processing methods for SLS and MJF parts currently available on the Protolabs Network platform. Ready to get your parts into production? Get an instant quote today, or read on for more on post-processing.
Curious about the cost and available material options for SLS and MJF?
The fastest and most cost-efficient method to add color to SLS and MJF parts is by dyeing them. SLS and MJF parts are porous, which makes them ideal for dyeing.
To dye a part, immerse it in a hot color bath - a large range of colors is available for SLS parts, with more color options on the way for MJF. Using a color bath ensures that you cover all internal and external surfaces of the part. Typically, the dye only penetrates the surface down to a depth of around 0.5 mm, which means that over time the color will fade and expose the original color of the powder. So, watch for wear and tear.
Chemical vapor smoothing enhances part performance and aesthetics. This seals surfaces, making it easier to dye and certify for contact with skin and food while maintaining dimensional accuracy. Chemical vapor smoothing isn’t restricted by line-of-sight only, unlike other post-processing methods. As well, you don’t end up with any fixture marks.
It’s important to note that while chemical vapor smoothing re-distributes surface material to provide a sealed, smoothed surface, it doesn’t create a polished surface. Your part’s surface topology will still be visible, as well as its minimal layer lines.
As SLS and MJF parts are printed using nylon powder, completed parts will have a coarse surface finish. Vibro polishing smoothes out the surface of the part via a tumbler filled with small media (generally ceramic beads) that vibrate against the surface of the model, removing the grainy texture. This method gives your part a smooth and slightly shiny appearance, similar to injection molded parts.
It’s important to note that vibro polishing and tumbling affect the part dimensions and round out otherwise sharp edges. We don’t recommend using a tumbler for parts with fine details and intricate features. Smaller, weaker parts are likely to be damaged after being exposed to vibrating media for several hours. As well, small ceramic beads may get stuck inside medium-sized gaps and trenches.
Vibro polishing and tumbling quality breakdown
Finish | ★ ★ ★ ★ ☆ | |
Tolerances | ★ ★ ★ ☆ ☆ | |
Speed | ★ ★ ★ ☆ ☆ |
The standard finish is your default for SLS printed parts. With this process, you remove parts from the build chamber and use compressed air to get rid of all the excess powder material. After this, you clean the surface via plastic bead blasting to remove any unsintered powder that may still stick to the surface.
This standard finish is inherently rough, similar in feel to medium grit sandpaper (satin-like matte that’s slightly grainy). However, it’s the best surface preparation for painting or lacquering your parts.
All SLS parts come with this standard finish unless otherwise specified.
Standard finish for SLS quality breakdown
Speed | ★ ★ ★ ☆ ☆ |
Other options for SLS and MJF parts include spray painting and lacquering. For both types of parts, you can spray paint them or coat them with lacquer (varnish or clear coat). Via lacquering, it’s possible to obtain various finishes such as high gloss or metallic sheen. Lacquer coatings can improve your part’s resistance to wear and tear, surface hardness and water tightness while limiting marks and smudges on its surface.
Due to the porous nature of SLS and MJF parts, we recommend that you apply four to give very thin coats to get a final finish, rather than relying on a single coat. An added benefit to this is that the finish will dry faster and reduce the likelihood of the paint or lacquer running.
Speed | ★ ★ ★ ☆ ☆ |
Both SLS and MJF parts can be electroplated. Stainless steel, copper, nickel, gold and chrome (and several combinations of these metals) can be deposited on the surface of parts to increase tensile strength and electrical conductivity in shielding applications.
Metal coating quality breakdown
Finish | ★ ★ ★ ★ ★ | |
Tolerances | ★ ★ ☆ ☆ ☆ | |
Speed | ★ ☆ ☆ ☆ ☆ |
Bead blasting uses rounded spherical media that impact the surface of the part, leaving a more uniform finish caused by the sphere “dimpling” the surface. This process is most often used when manufacturers require a smooth, uniform finish or a dull “satin” finish.
Bead blasting involves using a spray gun to shoot fine media in a bead or sphere to smoothen 3D printed objects.
While all post-processing options will add to the cost of your custom parts, Vapor Smoothing is the most expensive operation. In general, it will raise the cost of parts by about 30%.
Isotropic finishing techniques tend to have minimal effect on part tolerances.
Secondary finishing methods will have an impact on lead time. Vapor smoothing and dyeing tend to take longer than media blasting, which is one of the quicker post-processing methods.
A correctly-sintered SLS or MJF part (printed in PA 12) will have some inherent water resistance, and you can apply coatings to enhance this. Silicones and vinyl-acrylates likely provide the best results, while polyurethane is not recommended for waterproofing. If you’re going for complete water resistance, we recommend a dip coating method. As well, an MJF part with a wall thickness over 4 mm is inherently watertight.
As a rule of thumb, we recommend avoiding features below 2 mm thick. The media used on tumbling or media blasting will degrade these features. If your part has assembly requirements involving sharp corners, post-processing may round out these corners. And remember to avoid using level features or including living hinges in your design if you plan to use vapor smoothing.
Read articleWant to learn about media blasting? Here’s a guide to using the post-processing technique, how it works, its common industrial uses, and more.
Read articleFind out about the range of surface finishes and materials that make for aesthetically pleasing custom parts.
Read articlePassivation is a chemical process used to enhance the corrosion resistance and durability of a metal. Find out how it works and when it’s a worthwhile addition to your custom parts.
Read articleLearn about the differences between Type II and Type III anodizing, their benefits, typical applications, and how to choose the ideal surface finish for your part.
Read articleWant to learn more about black oxide coating? In this article, we’ll take a look at black oxide as a surface finish, its history, common applications, and more
Read articleHow do you add logos, lettering, serial numbers and other customized designs to your custom parts? Part marking is a cost-effective way to give parts those extra identifying and/or cosmetic details. Learn the common part marking techniques on the market today, including laser engraving and silk screening.
Read articleWhat is powder coating and in what cases should you select it as a finish for CNC-machined metal parts? This article covers the details of the powder coating process, as well as when to choose it for the best performance and quality.
Read articleWhat surface finishes are available for CNC machining? You can apply post-processing and surface finishes to improve the surface roughness, cosmetic properties and wear resistance of metal parts. Learn about the most common ways to finish CNC machined parts, and how to select the best methods for your applications.
Read articleA comprehensive guide describing the range of post-processing options for FDM printed parts
Read articleWhat are the post-processing methods and steps for SLS and MJF 3D printing? In this article, we explore the most common post-processing methods, including dyeing and metal plating.
Read articleWant to learn about electroless nickel plating? Here’s a guide to using the post-processing technique, how it works, its common industrial uses, and more.
