Passivation is a chemical process used to enhance the corrosion resistance and durability of a metal. Find out how it works and when it’s a worthwhile addition to your custom parts.
Passivation involves treating a metal surface with an acid solution to remove free iron and other contaminants to restore the thin, protective oxide layer. This oxide layer acts as a shield, preventing the metal from reacting with its environment and reducing the risk of corrosion. Passivation is commonly used on stainless steel and other metals to improve their resistance to rust, staining, and other forms of deterioration.
Stainless steels are the most common materials that require passivation, which is typically achieved with nitric or citric acid. Anodizing is also a common method of passivation, which is commonly used on aluminum, as well as magnesium and titanium. The protective oxide layer this treatment provides also allows for the metal to be dyed. Read more about how anodizing works. passivated with nitric or citric acid. Additionally, electropolishing can be used to achieve passivation.
The passivation process involves several steps. First, the metal surface is thoroughly cleaned to remove any contaminants. Then, the cleaned metal is immersed in an acid solution – usually a mixture of nitric acid and water – which removes or eliminates free iron and other impurities from the surface.
As the acid reacts with the metal, it triggers the formation of a very thin oxide layer composed of metal oxides – like chromium oxide, in the case of stainless steel. Although this layer is incredibly thin and invisible, it plays a vital role as a protective barrier. By acting as a shield between the metal and the environment, the oxide layer prevents oxygen and moisture causing corrosion or rust.
Passivation is commonly used on stainless steel, but it can also be applied to metals like titanium, aluminum, and magnesium in the form of anodizing. The primary focus is on metals that naturally form a protective oxide layer, which contributes to their corrosion resistance. The passivation process is particularly important for stainless steel, where it helps maintain the integrity of the oxide layer on the surface, ensuring continued corrosion resistance.
There are several key reasons for applying passivation to parts as a post process. Here are its benefits.
Corrosion resistance. Passivation creates a protective oxide layer on the metal's surface, significantly improving its resistance to corrosion and rust in various environments.
Durability. Treated metals have a longer lifespan due to reduced susceptibility to degradation caused by exposure to corrosive agents, moisture, and other environmental factors.
Maintained properties. Passivation preserves the inherent properties of metals, such as their mechanical strength and electrical conductivity, while making them more resistant to corrosion-related degradation.
Long-term cost savings. By preventing corrosion and the need for frequent replacements, passivation can lead to substantial cost savings over the long term, especially in industries where equipment durability is critical.
While passivation offers numerous benefits, there are also some potential disadvantages to consider. Here are a few of the most common.
Complexity. Passivation involves precise control of chemicals, concentrations, and process parameters, which can make it more complex and time-consuming than other surface treatment methods. Additionally, treating large or intricate metal components can be challenging, as ensuring uniform coverage across all surfaces may be difficult.
Limited effect on existing damage. Passivation is best suited for preventing corrosion on clean surfaces. It may have limited effectiveness in restoring severely corroded or damaged metal surfaces.
Material limitations. Passivation is most effective for metals that naturally form a protective oxide layer. It may not be as suitable for materials that don't readily develop this layer.
By incorporating these best practices, you can increase the likelihood of achieving consistent and effective passivation results for your parts while minimizing potential challenges.
Material selection. Choose materials that naturally form a protective oxide layer, such as stainless steel. Avoid materials that might not benefit from passivation or could be adversely affected by the process.
Avoid complex shapes. Design parts with simple, accessible geometries. Complex shapes with crevices, corners, and hard-to-reach areas can trap chemicals and hinder proper rinsing during the passivation process.
Smooth surfaces. Opt for smooth surface finishes with minimal surface defects. Smooth surfaces are easier to clean and passivate effectively.
Eliminate sharp corners. Sharp corners and edges can be difficult to passivate uniformly. Rounded edges are more amenable to passivation and rinsing.
Minimize welds. If possible, minimize the number of welds on a part or consider designing them in a way that avoids tight crevices where chemicals might accumulate.
Proper drainage. Ensure proper drainage by designing parts to allow liquids to flow freely and not get trapped in recesses. This prevents the accumulation of passivation chemicals.
Clearances and gaps. Provide adequate clearances and gaps between components to allow proper chemical circulation and rinsing during the passivation process.
Deburring. Remove burrs and sharp edges, as they can harbor contaminants and complicate the passivation process.
Passivation is widely used in industries such as aerospace, pharmaceuticals, food processing, and electronics to ensure the longevity and reliability of metal components in various applications. Let’s take a look at these industries, and the applications used within them.
Aerospace. Aerospace applications involve passivation to protect critical components like aircraft turbine blades and structural elements from corrosion in demanding and varied environments.
Pharmaceuticals. Passivation is crucial for pharmaceutical manufacturing equipment, ensuring that stainless steel vessels and piping maintain sanitary conditions and resist corrosion during drug production.
Food processing. Passivation is employed in food processing equipment, safeguarding stainless steel tanks and machinery from corrosion, and ensuring compliance with sanitation standards.
Electronics. In electronics manufacturing, passivation protects sensitive components and connectors on circuit boards from environmental factors, enhancing their reliability and longevity.
Medical devices. In the medical industry, passivation increases the biocompatibility and corrosion resistance of surgical implants such as orthopedic implants and cardiovascular stents.
Automotive. Passivation finds use in automotive parts such as engine components and exhaust systems, enhancing corrosion resistance and durability, especially in regions with harsh weather conditions.
To get an instant quote for a custom part with anodizing as a post-process, upload a CAD file for instant pricing and lead times. Passivation for steel and other metals is available as a custom request. Contact support@hubs.com to discuss your requirements.
You can also read more about post-processing and surface finishes, and how to choose the right process for CNC machined parts.
It prevents corrosion, extends lifespan, and maintains metal properties.
Stainless steel, titanium, aluminum, and other corrosion-resistant metals are all good candidates for passivation.
While passivation offers long-term protection, it can degrade over time in aggressive environments.
Passivation reduces rust but doesn't eliminate it entirely, meaning upkeep is essential.
Passivation works best on clean surfaces; it's less effective on heavily rusted areas.
When properly managed, yes. However, the passivation process involves handling chemicals and adhering to safety protocols.
Read articleWant to learn about media blasting? Here’s a guide to using the post-processing technique, how it works, its common industrial uses, and more.
Read articleFind out about the range of surface finishes and materials that make for aesthetically pleasing custom parts.
Read articlePassivation is a chemical process used to enhance the corrosion resistance and durability of a metal. Find out how it works and when it’s a worthwhile addition to your custom parts.
Read articleLearn about the differences between Type II and Type III anodizing, their benefits, typical applications, and how to choose the ideal surface finish for your part.
Read articleWant to learn more about black oxide coating? In this article, we’ll take a look at black oxide as a surface finish, its history, common applications, and more
Read articleHow do you add logos, lettering, serial numbers and other customized designs to your custom parts? Part marking is a cost-effective way to give parts those extra identifying and/or cosmetic details. Learn the common part marking techniques on the market today, including laser engraving and silk screening.
Read articleWhat is powder coating and in what cases should you select it as a finish for CNC-machined metal parts? This article covers the details of the powder coating process, as well as when to choose it for the best performance and quality.
Read articleWhat surface finishes are available for CNC machining? You can apply post-processing and surface finishes to improve the surface roughness, cosmetic properties and wear resistance of metal parts. Learn about the most common ways to finish CNC machined parts, and how to select the best methods for your applications.
Read articleA comprehensive guide describing the range of post-processing options for FDM printed parts
Read articleWhat are the post-processing methods and steps for SLS and MJF 3D printing? In this article, we explore the most common post-processing methods, including dyeing and metal plating.
Read articleWant to learn about electroless nickel plating? Here’s a guide to using the post-processing technique, how it works, its common industrial uses, and more.
