Makerbot Replicator 2/2X MightyBoards! Rev H
FOR SALE!! Makerbot MightyBoard Rev H for the Replicator 2/2xThis board has been fully tested as working, drop in replacement. Note:  I have been getting some questions on these, if you have a Rev G board you CAN swap with a Rev H board, HOWEVER, the difference is the power connector.  The Rev G board has a female socket and the plug is a male, on the Rev H the socket is the male and the power adapter plug is a female.  I have swapped these before to fix printers and it works no problem other then the power connector!  If you have a Rev G thats dead and need a replacement you can replace the connector on the board, or i can do it, but inquire first as i have a limited number of female jacks for doing this! The following tests were performed in a Replicator 2x. 1. Preheat Bed and Both Extruders, Fans on extruders cycle on and off at 50c as they should, maintains temperature.2. Unload and Load filament on both Extruders.3. Jog X, Y, Z back and forth between both extremes of movement, checking full movement and Endstop functions.4. Print from SD Card, 1 hour test print to verify function of all aspects of the board.5. Connected to USB and Simplify3D and checked for control and print from USB. This is a fully functional and ready to swap in board if yours is damaged.  Due to the nature of these devices and the potential for damage if improperly installed or connected this is a no returns sale.  The board has been fully tested to insure it functions correctly before shipment. I have them available with or without Botsteps installed.
 $175 for with Botsteps, $150 for without.  Multiple boards are available, all of them have been tested and repaired as necessary and thoroughly tested again.  If you have been looking to repair a 2 or 2x or just want a spare handy heres your chance to get some at a fair price. I also have some spare Carrier PCB's for the front panel, if your SD card slot has stopped working i have replacements, no need to replace the entire display unit from Makerbot when you can just swap the board.  I also repair these boards if you want one repaired!  $50 each for the Carrier PCB. I repair MightyBoards!
Without Botsteps
This thermocoupler is manufactured in Australia to higher specifications than the Makerbout out of the box thermocoupler that comes with the Makerbot Replicator 2 and 2X Our Thermocoupler is made of thicker stronger wire, it has stronger kapton sheathing and is resin reinforced at the sensor.
@CrazyHamSales Do you repair FlashForge Creator Pro boards? They are almost identical but slightly different.
I havent had my hands on one yet, but i certainly could try, from what i can see from pictures online they aren't much different then the original FlashForge boards that i have worked on.
Whats wrong with the one you have?
The extruder ports, where the wires connect to the board are bad.
Is it just the connectors that are bad or?  If you can send me a picture of it i can see if i have or can get parts for it.
Not the answer you’re looking for? Ask a new question to 69 For Sale experts active on Talk.
