Sounds like your hotbed is not screwed down properly, or has vibrated loose, my suggestion to you is to flip the unit over, and check every screw nut bolt, belt, make sure everything is snug, not reefed down, but snug., belts are tight, but should be able to be squeezed to touch each other in center of axis., check the gears on the x, y, and extruder, they should be tight, the extruder is brass and soft , check if it’s stripped, I had to tap mine to next larger size , m4 x 70 thread, very easy job, and use next larger grub screw., once yo do all this, then the two z axis screws are not centered, to the left end of the axis there are two screws that hit the end of the two horizontal smooth rods, they push on the ends to help fine tune the level of your x axis by loosening one and tightening the other, you can level it, thereby centering the rods., I only wrote this for others searching the issues normal., I would guess this is a mechanical problem vs software…
