I have a couple of builds that won’t possibly fit on the bed. Is there any decent software out there to cut it 2 or 3 ways?
simplify3d is a solution.
you can determine where to start and where to end your print.
exept for the fact that this does not create a propper connection for you individual parts.
better is to create your part directly sections.
3D Builder, native in Windows 8 onwards does the job simply and for free.
I use the split tool in solidworks that lets you split a part as much as you want, but that might not be a free solution unless you get a trial or student version. I would think that any CAD software would have a similar tool though
The best solution I have found is to import the STL into Tinkercad.com. Once it’s there, I usually copy and paste a second copy of the part. I then create a huge cube to be placed over the part that I want gone and subtract it from the model with the hole - join feature. I do this for both copies if the part than place them at 0.00 on the XY plane wherever I would like them to be laid out on the build plate. Download this new file for 3D printing and you’re good to go! I realized while typing this that it seems quite complicated… but it’s not. I’d be happy to create a tutorial video if anyone is interested. Jared
I would love to see a video.
I’m trying to work out how to build functional parts that are large also…
Screw together, bolt together, slide in place/lock down, poppit connectors. There has got to be a science already here that I don’t know about. (duh!)
There are all sorts of requirements that could be listed and then selected out of a table for use.
Lots of solid space both parts, constrain radial (degrees/force), surface areas, joint type, adhesives.
Slic3r (aka slow) has the ability to slice parts during build plate layout. I haven’t figured it all out yet since I usually have
gcode and not stl when at the printer and I always use Cura…
Me too :slight_smile:
3rd’ed
I should have a tutorial video posted within the hour. Stay tuned…
Here it be! Hope this helps. I apologize for the crappy audio, as I was just recording from my laptop. :slight_smile:
