This is just my hobby, I hope this helps someone out. I had to change the bushings and thought I’d make a video of it.
I need the specs of those 8mm bushings. Nowhere available in South Africa.
So the bushing is 12 mm diameter. 8 mm wide and 7 mm inside diameter.
Thanks for the response
I would just like to confirm the inside diameter. 7mm on a 8mm rod?
Its somewhere in between but its 8 mm inside. I got that wrong.
Deon, kon jy al daardie brass bushes vind? Ek sit met dieselfde probleem.
